Cylinder leakage?
/ Cylinder leakage? #1
snal
NC
Kubota BX24
The left (FEL) cylinder is leaking on my new BX24, leaks enough in a week to leave a stain on the garage floor (bucket down, pressure off) is this pretty normal?...or should I return for warranty service?
/ Cylinder leakage? #2
It should not leak and yes the dealer should make it right.
Is it leaking at a fitting? One of my backhoe fittings was loose on my new BX24. One of the fittings was about hand tight. A quick snug with a wrench did the trick.
Hope yours it that easy.
/ Cylinder leakage?
I looked a little closer this morning, it may indeed be coming from the fitting, so hopefully a turn of the wrench will fix it.
/ Cylinder leakage? #4
If tightening does not do it you may have a cracked fitting. That is easy to replace.
/ Cylinder leakage? #5
just a little bit of hydraulic fluid makes a big mess. A couple of fittings on my B7800 loosened up in the first 10 hours.
Snugged them up with a wrench and the leak was fixed.
/ Cylinder leakage? #6
I had the same problem. A small puddle of hydro fluid after every use. Mine had a cracked fitting when tractor was delivered. Dealer replaced it. No more leaks.
UNUSED (15) SDLANCH PROTECTION MATS (A64281)
UNUSED (15)...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
Deere 120 (A64119)
Deere 120 (A64119)
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
