Cylinder leakage?
/ Cylinder leakage? #1
snal
NC
Kubota BX24
The left (FEL) cylinder is leaking on my new BX24, leaks enough in a week to leave a stain on the garage floor (bucket down, pressure off) is this pretty normal?...or should I return for warranty service?
/ Cylinder leakage? #2
It should not leak and yes the dealer should make it right.
Is it leaking at a fitting? One of my backhoe fittings was loose on my new BX24. One of the fittings was about hand tight. A quick snug with a wrench did the trick.
Hope yours it that easy.
/ Cylinder leakage?
I looked a little closer this morning, it may indeed be coming from the fitting, so hopefully a turn of the wrench will fix it.
/ Cylinder leakage? #4
If tightening does not do it you may have a cracked fitting. That is easy to replace.
/ Cylinder leakage? #5
just a little bit of hydraulic fluid makes a big mess. A couple of fittings on my B7800 loosened up in the first 10 hours.
Snugged them up with a wrench and the leak was fixed.
/ Cylinder leakage? #6
I had the same problem. A small puddle of hydro fluid after every use. Mine had a cracked fitting when tractor was delivered. Dealer replaced it. No more leaks.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2021 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A61572)
2021 Caterpillar...
UNUSED WOLVERINE QUICK COUPLER 8 (A64281)
UNUSED WOLVERINE...
300 Gal Fuel Tank (A64119)
300 Gal Fuel Tank...
KUBOTA BX2380 TRACTOR (A64280)
KUBOTA BX2380...
2000 Jeep Wrangler 4x4 SUV (A61574)
2000 Jeep Wrangler...
