Cylinder drift
   / Cylinder drift #1
jmfox
Platinum Member
What causes a double action cylinder with no leaks to drift? Every other cylinder on the system does not drift.
jmf
   / Cylinder drift #2
The fluid is bypassing the piston seals internally. It sounds like it need to be rebuilt.
   / Cylinder drift #3
Yep, internal bypassing is the usual answer 99% of the time. The other 1% is a worn control spool.
It is leaking, but not where you can see it.
jb
   / Cylinder drift #4
You may also have a seal that is nicked that is causing this. Possibly in the cylinder or in the loader valve. It should be pretty easy to fix.
   / Cylinder drift
Thanks. If you can't see something leaking, it doesn't mean it's not leaking. On removing it I noticed it is rebuildable, so I guess the best thing to do is take it down to the cylinder rebuild shop.
jmf
2005 Manac AAF-48 50 Ton 48ft Flatbed T/A Equipment Trailer (A51692)
2005 Manac AAF-48...
Manac Walking Floor Trailer (A50322)
Manac Walking...
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
Adams 5T High Clearance Fertilizer Spreader (A53473)
Adams 5T High...
1997 Dynapac CC142 14 Series Double Drum Roller (A52384)
1997 Dynapac CC142...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
