Rake Cylinder Angle Bracket for Woods Landscape Rake LR700
   / Cylinder Angle Bracket for Woods Landscape Rake LR700 #1
LouieJunior
Platinum Member
Moline, Illinois
JD4052R Open Station
I wish to add a hydraulic cylinder to my Woods LR-700 Landscape Rake. I have everything except part 20453, which is the mounting bracket for the hydraulic cylinder. Woods no longer has this part and I have been unable to locate one.
Before fabricating something to work I thought I'd ask if there are there any other Landscape Rakes or Rear Blades that use a similar type bracket? Unfortunately, I am not a welder. I posted this in hydraulic section earlier.
   / Cylinder Angle Bracket for Woods Landscape Rake LR700 #2
A welding shop should be able to build you the bracket. You may have to bring them the rake and drawing so they can make measurements. Make sure they put the rear cylinder mount at the same height as the rod cylinder mount on the rake, so it does not bind.
2014 COTTRELL CX-09LS2 AUTO HAULER (A52576)
2014 COTTRELL...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
