CX2510 No Start - SOLVED
/ CX2510 No Start - SOLVED #21
Pretty decent chance you need to replace the Safety Start Controller unit. This is mounted under the seat on the left side of the transmission. That will probably solve your issue.
Hope this helps
This was my first thought too - however in the past I have had Safety Modules burn out and still was able to start them when jumping at the starter. Affecting glow timing definitely would do it though. Interesting.
/ CX2510 No Start - SOLVED #22
I've been reading through the WSM and I'm thinking I have a fuse blown on the engine wiring harness that's causing no power to get to that harness at all. That would explain the fuel cut solenoid and starter relay not functioning properly. I'll do some multimetering tomorrow to see where I'm getting 12v or not.
I was thinking fuse related as well - I would trace fuses and look for a blown fuse
A lot goes through this safety control module. I'm not sure I like this if this indeed does end up being the issue.
  • TB150[CX2510(H),CX2510(H)(N)-EU]_WM-ALL-200327 402.pdf
@MichiganIron - Is there a way to bypass this thing to verify this is the issue? I've already spent half a day trying to get a dead tractor lined up with my borrowed trailer before realizing the loader/grapple isn't going to clear the ramps.
/ CX2510 No Start - SOLVED #25
We had a safety control module go out on a CK2610 cab - we were able to jump at the starter and get it running again - replaced the module and it started via key after that with no issues. I didn't realize the module controlled glow timing as MIE said, learn something new!
And the fuel cut solenoid apparently. If this ends up being the issue I may end up buying one to put on the shelf if they're not too expensive. Kind of a critical part if it can't be bypassed.
KISS...
Which slot do you think this fuse belongs to??
So clearly the Safety Control Unit is significant bottleneck on this model of tractor. Obviously my issue was just a fuse but it still concerns me that if this control unit goes **** up my tractor is dead. Then the question is whether Kioti still makes replacement units when/if that ever happens.
/ CX2510 No Start - SOLVED #28
KISS...
KIOTI still stocks controller units for 15 year old tractors. I would not be concerned about the availability in the future. A blown fuse is usually a symptom of an issue, not always the cause. That is obviously the safety controller fuse. Best to try a new fuse and work with your selling dealer for a replacement Safety Controller if the issue continues. You cannot start the tractor by simply jumping the starter motor since the Safety Controller also controls the fuel solenoid signal. Certainly annoying, but at least you know it's a simple issue to deal with. Blame it on there being too many attorneys running around. Manufacturers are forced to address as many situations as possible.
"Every problem is a result of a solution to a previous problem."
Hope this helps
/ CX2510 No Start - SOLVED #29
I'm glad to see this resolved!
MIE - good info on the safety control module, I did not know that. Thank you
/ CX2510 No Start - SOLVED #30
Nope. And it may not be the box either. It could be anywhere in between along the harness(es), a chafe, a rodent chew, a pinch, maybe even water/corrosion in a connector.
But in general, a fuse won't blow without a reason.
So in this case it'd have to be between the fuse block and the 12v+ pin (1) on the unit right?
/ CX2510 No Start - SOLVED #32
If the fuse blows again, take a good look at the harness running along the left side of the clutch housing directly behind the clutch release lever. It's a tight spot to get to, but the harness runs in the corner of the clutch housing right behind (and close to) the release lever. If it comes loose of the harness loops, it can get rubbed by the clutch linkage.
/ CX2510 No Start - SOLVED #33
Everyone keeps talking about jumping the starter. I have a Kioti cx2510 and I tried that and all I get is a hi speed whine. sounds like something is not catching. I guess I am doing something wrong. I have had my tractor for less than a year without issue now turn the key and nothing. I check the seat sensor and it only shows 5 ohms resistance.
Did you check the fuse?
/ CX2510 No Start - SOLVED #35
You could also have a bad ground somewhere.
/ CX2510 No Start - SOLVED #36
Today it fired right up and I used it for 2 hours. I put it back in the barn. I could restart it easily. I left it in the weather one night, drought ended and it rained for the first time. The next day it wouldnt start. I will be checking daily to see if continues. If it doesnt that there is an issue with moisture. I checked the seat sensor and it was running 5 Ohms when engaged. I read it should be 22 Ohms. I figured that was the issue.
If I can get it started then I can load it and bring it to the dealer for service.
Thank you for your help.
1981 Chevrolet Corvette (A62613)
1981 Chevrolet...
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2006 KENWORTH W900 T/A DAYCAB ROAD TRACTOR (A64276)
2006 KENWORTH W900...
(2) 10 LUG WHEELS (A64281)
(2) 10 LUG WHEELS...
Hurricane THB750 Hydraulic Breaker Excavator Attachment (A61572)
Hurricane THB750...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
