CVT Belt replacement
/ CVT Belt replacement #21
ANYONE got a match on equivalent CV axles for the TH4400?
They are not the same as the Sportman but are SUPER close, the outer shaft is just a bit longer on the smooth part before the splines start so they don't come through enough to install the castle nut.
Front CV axle measurements:
25.5" compressed
27" extended
Inner shaft: 1.75" overall length, 22 splines
Outer shaft: 1.25" smooth section to taper, 20 spline, 4 5/8" overall length
DOES NOT WORK - TRIED: ATVPC (parts connection) - eBay - fits except for outer shaft too short to fit through wheel hub
Front CV Axle Pair for Polaris Ranger 500, 700, XP 700 4x4 6x6 2005-2007
From <Security Measure>
Rear CV axle measurements:
21" compressed
23" extended
Outer shaft: 1.25" smooth section to taper, then 20 spline, 4 5/8" overall length
TRIED: NICHE industries - fits except for outer shaft too short to fit through wheel hub
DOES NOT WORK: NICHE Axle Front Drive Shaft High Strength for 2005-2006 Polaris Sportsman 400 450 500 600 1380234 1332422 2 Pack
From <https://www.amazon.com/gp/product/B07XWG7QJ4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1>
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
HYSTER H80XM STRAIGHT MAST FORKLIFT (A64279)
HYSTER H80XM...
(6) 150 TON MOVERS (A64280)
(6) 150 TON MOVERS...
(2) BUCKETS OF GALVANIZED BOLTS (A64281)
(2) BUCKETS OF...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
