CVT Belt replacement
/ CVT Belt replacement #21
ANYONE got a match on equivalent CV axles for the TH4400?
They are not the same as the Sportman but are SUPER close, the outer shaft is just a bit longer on the smooth part before the splines start so they don't come through enough to install the castle nut.
Front CV axle measurements:
25.5" compressed
27" extended
Inner shaft: 1.75" overall length, 22 splines
Outer shaft: 1.25" smooth section to taper, 20 spline, 4 5/8" overall length
DOES NOT WORK - TRIED: ATVPC (parts connection) - eBay - fits except for outer shaft too short to fit through wheel hub
Front CV Axle Pair for Polaris Ranger 500, 700, XP 700 4x4 6x6 2005-2007
From <Security Measure>
Rear CV axle measurements:
21" compressed
23" extended
Outer shaft: 1.25" smooth section to taper, then 20 spline, 4 5/8" overall length
TRIED: NICHE industries - fits except for outer shaft too short to fit through wheel hub
DOES NOT WORK: NICHE Axle Front Drive Shaft High Strength for 2005-2006 Polaris Sportsman 400 450 500 600 1380234 1332422 2 Pack
From <https://www.amazon.com/gp/product/B07XWG7QJ4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1>
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
Toro Groundmaster 228D (A64912)
Toro Groundmaster...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
2011 Caterpillar 299C (A64911)
2011 Caterpillar...
