Price Check cv joint maintanence
/ cv joint maintanence #1
1965tontruck
Is there any maintanence that needs to be done on the 4 cv joints? I checked the owners manual for grease points and did not see anything. In addition, any maintanence for the rear suspension?
Thanks for the help.
/ cv joint maintanence #2
None that I know.
Thanks for the input radman. I search high and low for grease fittings.
/ cv joint maintanence #4
If you've got a "D" model, and it sounds like you do, there is a traditional zerk on the top of each upper ball joint (I guess that's what they're called) for a total of four suspension-related zerks. One zerk for each corner of the machine. I'm not aware of anything CV joint specific. If you don't see the zerk on top of the ball joint, it may mean that it was torn-off due to debris, loose tire chains, etc. The front and rear differentials also take a special lube that is supposed to be changed-out after the first 1000 hours.
A Bobcat technician once warned me about over-lubing the ball joints. He gave each zerk one or two pumps of grease.
I have an A model, but you givesome food advice.
Mini Metal Standing Fire Pit (A61569)
Mini Metal...
2016 Ford F-350 Pickup Truck (A61568)
2016 Ford F-350...
(2) 330 GALLON POLY TOTES W/ CAGES (A62131)
(2) 330 GALLON...
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
