Cutting with a stick welder?
   / Cutting with a stick welder? #31
Turn your Plasma down to about 35 amps and you can surgically remove old welds with much less fire and mess than an Arc Air set up.
   / Cutting with a stick welder? #32
When I revamped a grapple to fit the FEL on my tractor, I used my plasma to scarf off the skid-steer mounts, wear strips, and to lighten it up. Plasma are truly cleaner to scarf with. :thumbsup:
   / Cutting with a stick welder? #33
6010 rod won't weld on AC but it will cut well. Soaking in water first helps them last longer. 20-30% more amps than usual and a sawing motion.
   / Cutting with a stick welder? #34
I would have never guessed that 6010 would work on AC for cutting - good to know if I ever have any laying around. I have always just used 6011 (which is what I have always seen recommended in Lincoln manuals for cutting) since I usually use what I have on hand to actually weld with. Only had AC for many years, now I do have AC/DC but I still stock the same rods I did before because they work well on either AC or DC and I have more range on AC.
Sawing motion is literally correct, but I always just tell people the manipulation technique is covered in the older Lincoln User's manuals (which it is). Unfortunately many people seem to have a tendency to laugh at yah when you mention sawing motion. However, if it comes from Lincoln then they believe it more easily.
2015 Land Rover Evoque SUV (A53424)
2015 Land Rover...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2022 Wacker Neuson LTV6 Towable Light Tower (A55851)
2022 Wacker Neuson...
