Cutting R Panel recommendations
/ Cutting R Panel recommendations #1
Philip_L
Folsom, LA
Kubota L185 2WD
My dad and I are building a shed with a gabled R Panel Roof and are looking for ideas. In the past we have used snips but the ridges in the panel tend to get bent and my hand gets tired, even using power snips. Some one told me try some pneumatic nibblers, but it still seems tough to make a straight clean angled cut with those. We were thinking of investing in a milwaukee metal cutting circular saw and a metal-devil blade. I am still worried it will burn the paint and the blade will wear out quickly.
/ Cutting R Panel recommendations #2
take a cheap plywood blade and put it in the saw backwards... and wear ear protectors - it's LOUD
/ Cutting R Panel recommendations #3
When I built my pole barn I used an old circular saw with the fiber type metal cutting blade. I would not reccommend it for a saw you care about, but it worked very well for me! also, cover your ears. and eyes.
/ Cutting R Panel recommendations #4
I've done the same when dismantling an old above ground pool and also for cutting up an old dishwasher, works suprisingly well. Any cheap circular saw blade will cut sheet metal. Don't use one with welded on carbide teeth, just a basic cheap blade.
/ Cutting R Panel recommendations #5
There are metal cutting blades that are simply disc with radial slots around the circumference They work well but probably generate more heat than a backward saw blade.
Vernon
/ Cutting R Panel recommendations #6
When I put up my steel building I used a metal cutting blade like texbaylea described. Bought it at HD I think. Worked well. It is very loud but gives a nice straight cut. Haven't tried the reversed basic blade, but apparently it works just as well.
/ Cutting R Panel recommendations #7
As suggested, a reversed plywood blade works great. Another suggestion is to make sure that the metal is supported underneath while cutting to avoid binding the blade. I used blue foam board resting on 3/4 inch sheet of OSB screwed to a couple of saw horses. On the smooth cuts you can score the metal with a box blade and fold it until it breaks. This works on new metal, not sure about aged metal.
Good luck.
Farwell
/ Cutting R Panel recommendations #8
What Mike said. That's the way roofers do it.
/ Cutting R Panel recommendations #9
I've never tried it with a plywood blade as I don't have any. I just use my old, worn out framing blades that I put on backwards. After using it, the blade is toast and time to through away, but it works great.
It's very LOUD!!! Also be sure to wear eye protection. I haven't had it happen, but it's just a matter of time until a small piece of metal comes off. When it does, the damage could be very bad.
After cutting the R Panel, be sure to put some paint on the edge. My roof is called Aspen Green and is a pretty good match with Rustolium Hunter Green in the spray can. I tried three shades of green to find the one that matched.
Eddie
/ Cutting R Panel recommendations #10
I'm not familiar with the R Panel roof but have used a lot of painted galvalume panels. I've tried the metal cutting blade for circle-saws as well as the plywood blade backwards. They both work but are clumsy.
I just finished a roof job on our house, and it has five gables to contend with. Started out with the metal-cutting blade and got aggravated. Then I thought about one of my favorite power tools... Bosch jigsaw. I think I broke two blades using the Bosch during the whole job. It works better and is much quieter.
Whichever tool you choose, I found that things work better if you put the panel face down on your sawhorses with 2x's supporting it between the ridges; mark your cut with a sharpie, and make the cut from the back side. That way your saw is riding a relatively flat surface, with the ridges protruding down instead of up. Easier to follow your intended cut line.
/ Cutting R Panel recommendations #11
When cutting with a power saw, brush off all the metal filings. On panels with a silicone polyester paint, they will etch into the panel if left on until they rust.
/ Cutting R Panel recommendations #12
Does anyone know if the warranty is voided on the panel if it is cut with a certain tool/method?
/ Cutting R Panel recommendations #13
I don't think the warranty would be an issue unless the rust isn't from scratches incurred in the cutting process.
We'll be cutting R panels at the get together at Don's place in Lee County.
We use everything from box knives to different saws. I personally can't handle the scream of the circular saw blade method. I have two different kinds of manual snips, aviation right, left, and straight, and sheet metal ships. I also have an Milwaukee electric shear and a Bosch nibbler.
Lengthwise cuts we've found are easiest accomplished with a box or utility knife if you can use a seam as a guide. You score the metal with the box knife and then bend the metal back and forth. It's a lot easier than it sounds, really.
The problem with the nibbler is the kazillion finger nail clippings it leaves. Imagine finger nail clippings that are made of steel with needle sharp edges. It cuts fast but it consumes about three eighths of an inch in the process.
The electric shear also works good for length cuts or cross cuts except for the R grooves themselves. Then you need two men and a boy to manipulate the panel to get the shear with it's foot in and around.
If the hand snips are in good condition they're the best for crosscuts if you don't have too many cuts. It's just hard. But it is what it is. So you have to suck up and just do it.
A lot of the professionals use a cutting torch with a small tip. Their burn mark is usually less than half an inch and is covered by trim. It takes some practice to get good using a torch. But a professional can make it look easy and neat.
I use a plasma on occasion. The burn mark is usually less than a sixteenth of an inch. If I did this professionally I'd probably invest in one of those combination one ten plasmas with the built in compressor. They can't cut much for thickness but with the sheeting you're only looking at twenty four gauge maximum.
The sheeting must be treated with respect. It's a razor blade when it gets some speed and makes a slicing cut. The trimmings are hazards even months later if not picked up for animals and the unwary human.
Any scratch can ruin the appearance of a wall under the right circumstances. A little scratch can produce rust stains much bigger than the rust line itself.
/ Cutting R Panel recommendations #14
So far, all I've found is that the recommended method is snips (manual or power) or a nibbler. I haven't seen anything that mentions voiding a warranty if other methods are used. I'ved used both and prefer power shears to nibblers.
/ Cutting R Panel recommendations #15
Just finished a bunch of metal siding and roofing on my garage extension, and found that the metal cutting fiber blade worked best in my Skil saw. I have tried the backwards plywood blade in the past, but it's slow and real noisy, plus the cut quality wasn't good. I got the blade for the saw at Lowe's for less than $4, and it still is in good shape, there are some sparks and noise so wear gloves and a long sleeved shirt. Like another person said, turn the sheets upside down so you're not sawing over the humps. I clamped a metal edge to the sheeting to use like a rip fence when sawing long lengths.
/ Cutting R Panel recommendations #16
Sometimes I really feel like an idiot. Turn the thing over, and don't scratch the paint or deal with the humps!
Just got through cutting 11 sheets today with a Masterhand (read chinese) metal cutting saw purchased from Tractor Supply a couple years ago. Worked well except for the guard hanging up on first cut, so I plunge cut first then backed up when i could.
I am here to learn, and you just taught me something today.
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
2010 Deere 318D (A60462)
2010 Deere 318D...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2009 Honda Civic Sedan (A59231)
2009 Honda Civic...
2014 Nissan Murano SUV (A59231)
2014 Nissan Murano...
