Cutting PTO Shaft
/ Cutting PTO Shaft #31
Tom, hopefully the more experienced TBNers can answer your questions. I'm a rookie at this PTO shaft stuff, too. /w3tcompact/icons/smile.gif
/ Cutting PTO Shaft #32
I used to switch the shaft from the snowblower to the tiller. The distance from the input shaft of the implements' gear box to the 3ph mounting pins, and the vertical distance between the same points were identical on both implements. My advice - buy another shaft. I screwed up the oil seal on my tiller the last time I removed the shaft.
2020 DRAGON ESP...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
Giyi XKH39 (A60463)
Giyi XKH39 (A60463)
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
