Cutting open oil filter
   / Cutting open oil filter #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Any one have a poor mans trick to this? I do my car filters with a sawzall but these hydraulic filters are thick. Figured there might be a better way...
Carl
   / Cutting open oil filter #2
very large pipe cutter like you use on copper pipe. thats what the ones you buy are like, cat has a manditory special tool that does just that.
   / Cutting open oil filter #3
I guess I am just dumb but why do you want to cut open a used oil filter?
   / Cutting open oil filter #4
I was wondering the same thing.
   / Cutting open oil filter #5
I use a filter cutter. Do a quick search online, there are many to be found. The one I have is made by Caterpillar Engine.
Why use one. So you can see if there is anything trapped in the filter media. I cut open all oil filters, mine and my customers. I cut out a wide piece of the filter media and squeeze out the oil in a vice and check for metal particles. I can check at the time I am servicing the vehicle/equipment and don't have to wait for the UOA to come back.
And a bit more of an explanation why... My Power-Trac was used. Left to sit out for a number of years. It was restored,, but in the first few days of operating it my filter clogged twice. This latest filter has gone fine. But I want to cut open the filters and just confirm it was sludge loosening up and coming free.
I have made it a plane to check the filters on my old car every 10K miles. For a while I will cut open every tractor filter I can...
Carl
   / Cutting open oil filter #7
We use filter cutter on our planes. I know you can find them at Sporty's Pilot Shop. Do a search on "Sporty's Pilot Shop", once there, search again for oil filters and you will find the cutters. Anything to do with planes aren't cheap though, so you might want to shop around
   / Cutting open oil filter #8
None of the good filter cutters are cheap. Nothing good ever is. :)
   / Cutting open oil filter #9
Good Ol Sportys. About 10 miles down the road from me...
KUBOTA M7-152 TRACTOR (A54756)
KUBOTA M7-152...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A55301)
2020 Westfield MKX...
2021 New Holland C327 Compact Track Loader (A55218)
2021 New Holland...
2019 FORD F-250 XL SUPER DUTY SERVICE TRUCK (A54756)
2019 FORD F-250 XL...
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
