Cutting Mixed Metals
/ Cutting Mixed Metals #21
I joined the local hackerspace and they have 3-phase high voltage power. A CNC plasma is on the list of projects for the space.
I talked to the Jet Edge guy at a trade show I seem to remember a 60hp motor driving a hydraulic pump which went to a ram pump which generated the cutting pressure. There are mobile systems. I guess for us tractor guys a PTO driven system would be the heat. Might win the prize for high-dollar attachment.
The garnet abrasive is not re-used. I had a small part cut locally a few years ago and they had to re-make it because it fell into the mud and they couldn't find it. The local places that do plasma, laser, and water jet are actually pretty reasonable.
/ Cutting Mixed Metals #22
So here is a question about phasing. If you can get 208 3 phase will that run a lot of these 3 phase tools? I know the big boys are 460 but.....
In a word, YES. Most machinery is set up to run on both high and low voltages. Just requires doing some simple switching of the internal wiring. You also have the option of using a step up transformer if low voltage is not an option.
I know we are way off my original question but I am very surprised at how much 3 phase gear exists and the low (my perception) price they seem to garner.
Then again, these all may be worn down beyond the level even a homeowner would want. Wouldn't even know what to look for.
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
