Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #251
Sincere thanks to all for this fabulous thread
I was just about to buy the chain and shackles to try to improve the grip on my Ford 6000 tyres but there is very little clearance between the tyres and the guards and fitting spacers onto these monsters would be a real hassle. As you can see in the pictures the rear tyres are badly worn but I can't justify $1500 a tyre to replace them when the beast is only used to grade the roads and clear the fallen branches etc in the scrub.
We don't get much snow here even though winter temperature goes down to minus 12 C - the problem is lack of traction on the dirt roads and in the bush especially when reversing up a steep slope when the rrear wheels just spin. This is why I found the discussion about siping very useful so I want to give it a try if you experts suggest it. Do you think a single cut along each tread bar would do, OR maybe longditudal cut plus a couple of 90 degree cuts?
Unfortunately, siping tools here are over $400 and the US ones don't run on our 230 V without a transformer, so options seem to be:
a) a butane torch with cutting tip - a bit small for the job
b) an electric soldering iron with modified tip - might work
c) a router - scary
d) a Dremel-type multi-tool with a cutter tip - might be best
Comments and suggestions most welcome
Alan
   / Cutting / Groving / Siping R-4 for snow #252
Good looking dog.
   / Cutting / Groving / Siping R-4 for snow #254
Actually - since last post, I think I have solved the tool issue - tried a 4" angle grinder with a nice fat cutter -It seemed to work well - slow but created a neat groove about 4 mm wide and 4 mm deep. However - the guard had to be removed to stop hot rubber building up between the disk and the guard. Later I tried a 4" abortech cutter in a 5" grinder so the extra clearance meant the guard could stay on - it did a much better job - faster, less heat. less mess and a nice clean cut
My other question remains - one cut or two and what about perpendicular cuts? The picture shows I made just one off centre. Would two weaken the tread too much?
Cheers
Alan
   / Cutting / Groving / Siping R-4 for snow #255
Your tires look similar to mine, not much tread left either.
But mine are "loaded" and i have no traction issues with them, 4X4 though.
Have you considered filling them.
   / Cutting / Groving / Siping R-4 for snow #256
G'Day Skyhook
Thanks for the suggestion. I did consider filling but the local tyre guy reckons it is unlikely to help.
There has been no feedback from the others on this forum about whether siping will work but I don't have a lot to lose by trying. Not sure if it will also help but perhaps "squaring off " the sides of the worn treads might help too. Anyone care to comment please?
Alan
   / Cutting / Groving / Siping R-4 for snow #257
I haven't tried it yet. From all reports, it is well worth doing. I plan to do a single sipe per tread. I recommend you go that way. If it works, great. If you can't discern a difference, why go to two?
PMH
   / Cutting / Groving / Siping R-4 for snow #258
I was going to say that the dirt biker all use tire groovers or hot knives to cut new corners on their tread blocks so that they have more bite and it looks like you could do that carefully.
The folks in this thread who tried siping and/or grooving for mud and dirt use didn't seem to think it helped as much as it did in the snow.
I personally have no experience with it, but I did buy a hot knife so I can get grooves cut on my R-4's before the next winter arrives.
I plan to do it late summer after the tractor has been sitting out in the sun for a few hours and they're nice and warm.
Thomas
   / Cutting / Groving / Siping R-4 for snow #259
Thanks guys - I'm making progress with the Arbortech cutter - maybe 20% through the job with a single sipe per tread. Also tried squaring off the edge of one tread but probably will not persist with that - very difficult job
I'll post more pictures later
Alan
   / Cutting / Groving / Siping R-4 for snow #260
I'm not sure Carl could stand the excitement of posting another tractor comparo....:D
But I'd like to hear too.
I have HDAP tires on my Gravely and they are superb in the snow, btw.
It's not the tires...that chrome exhaust tip is what really makes it work better!! :D
TROYBILT TB685 EC WEEDEATER (A54757)
TROYBILT TB685 EC...
John Deere 7230 131HP 4WD Agricultural Utility Tractor (A56857)
John Deere 7230...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
Craftsman ZTL 7000 Mower 42in mowing deck Parts/Project (A55315)
Craftsman ZTL 7000...
