Snow Equipment Owning/Operating Cutting / Groving / Siping R-4 for snow
   / Cutting / Groving / Siping R-4 for snow #172
Here is a article where some fellows documented their experiences with pictures for grooving big truck tires.
4WD Magazine
   / Cutting / Groving / Siping R-4 for snow #173
I'm ordering my groover tonight. I've been following this since last year, and I'm finally sold. Rears are a no brainer. I'd really like to hear from you guys who did the fronts, though. Really not sure what pattern to use. I have a steep hill, so traction is a concern, but side slip is too. I would like to compare the parallel groove vs multiple perpendicular grooves on the fronts with regards to side slip. I'm kind of thinking I'll do 2 perpendicular grooves on each side of the centerline, and either leave the center smooth as is, or possibly run a real short parallel groove right at the center. Thoughts?
   / Cutting / Groving / Siping R-4 for snow #174
Deadman, in post #64 in the picture of the rear tires I see a chalk like on the outside of your tires. How much tread did you leave on the outside? 1 inch or 2? The tires look tremendous. My knife is supposed to arrive next Monday. Thanks for the help. :thumbsup:
   / Cutting / Groving / Siping R-4 for snow #175
I wonder if 1/2 inch rope wound around the rear tires would work as well as chains without the problem of tearing up an asphalt surface? Probably have to replace the rope each season, or maybe even monthly depending on wear.
   / Cutting / Groving / Siping R-4 for snow #176
When I was a kid and we wanted to ride our bicycles in the winter time, we wrapped baler Twine around our tires to act as chains and it did wonders on ice. That was back before bicycles had hand brakes and you stopped them by pushing your pedals backwards. Did anyone else ever do that? I think it would be worth a try especially on ice.:thumbsup:
   / Cutting / Groving / Siping R-4 for snow #177
Yes, I did the same thing with heavy twine, my old town was all hills. (Springhill)
   / Cutting / Groving / Siping R-4 for snow #178
I installed a set of 2 Link Ladder chains on my tractor this morning. Although traction is awesome the ride is horrible. I travel on the road often and the ride is unacceptable. I will be taking the chains off tomorrow.::thumbdown:
I ordered my Ideal heated knife tonight and will grove my R4s. Thanks for this excellent thread. I will post some pics when finished.
   / Cutting / Groving / Siping R-4 for snow #179
My rear chains were grader quality 7/16 cross links and created a very rough ride too until I dropped the tire air pressure to 10 lbs.
2017 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2023 Chevrolet Tahoe (A54815)
2023 Chevrolet...
4 Unused Montreal ST205/75R15 Trailer Tires (A55788)
4 Unused Montreal...
2002 Henderson 8X Mild X Sandspreader Attachment (A55973)
2002 Henderson 8X...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
