Cutting Granite
   / Cutting Granite #1
Transit
This is way off the subject of welding. I have six granite boulders, that is, I think they're granite. About 4 ft in diameter, that weigh about 2.8 tons each. I can roll them with my tractor, much too heavy to lift. I've been trying to drill holes or cut groves in them without much success. The stone is harder than any tungsten carbide drill I have. I've tried a diamond saw blade too and nothing makes a dent. These boulders are the world's largest diamonds or they're from outer space. What have I over looked? :confused:
   / Cutting Granite #2
Your going to need a pneumatic rock drill. Think jackhammer:D
Local rental store should be able to gear you up
A large hunk of granite will usually laugh at a electric hammer drill unless its one of the very large models.
Once you get holes drilled, you can fill them with expanding cement(dexpan) and split the rocks to a more reasonable size, or use feathers and wedges manually.
Or hire this guy for $5 a day :Dhttp://www.youtube.com/watch?v=CDoXOYDyfXw
   / Cutting Granite #3
   / Cutting Granite #4
Up here I use a Makita hammer drill and angle grinder with a stone blade in for cutting the local granite boulders.:D Then wedges and feathers for splitting.:D
The rocks I've been working on have much much smaller though.
   / Cutting Granite #5
How do you know how much they weigh?
   / Cutting Granite #6
Egon, about how long does it take to split your pictured rock into the three pieces? The middle piece looks very useable. BTW - I notice you haven't worn the label off your hammer yet :D:D
Dave.
   / Cutting Granite #7
I have to agree with Egon and some of the others. I have made alot of big rocks into littler rocks with an electric hammer drill and some feather and wedges. If your looking to get some usable slabs the feather & wedges work great for making a controled split. Egon's picture shows it perfectly. If you want to waste money, make alot of noise and wind up with a pile of rubble, go for the air compressor
   / Cutting Granite
That's the easy part, the boulders are almost spherical and 4 ft in diameter. Calculate the volume in cubic feet. Knowing the density of granite in pounds per cubic foot. Vol x den = weight.
   / Cutting Granite
Once I can get past drilling holes, the rest is easy. What I'm seeing is my tools are not up to granite.
   / Cutting Granite #10
I've got some boulders I want to move around, and I guessed they were around 2 ton, so I guess I was close. This is one rose out of the ground a little more each year became a traffic hazard.
1065 (A53342)
1065 (A53342)
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
2015 Hitachi PC138 (A47477)
2015 Hitachi PC138...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
