Cutting edge for b21
/ Cutting edge for b21 #1
mopar3500
Guys, need some help. I noticed on the new b26 that it came with a cutting edge on the front bucket. My dealer told me that it would not fit my b21 because the bucket is bigger. So I noticed that the 06 b21 came with one. They want 200.00 for the edge and 150.00 to install it. I dont know but I can buy a plow cutting edge for an 8 ft fisher for about 100.00. Is this price way out of whack. Does any one have any other suggestions. Thanks
/ Cutting edge for b21 #2
Your dealer must not want to mess with this. The bolt on cutting edge for an GL series 72" HD bucket lists for $200 via the Kubota configurator. And the $150 to install it doesn't make sense, unless your B21 bucket did not come pre-drilled for the edge.
FWIW I did not pay anything close the prices in the configurator when I bought my GL3240 this summer. My 66" HD QA bucket came predrilled for the cutting edge.
Talon Dancer
Thanks guys. Talon Dancer you are right my bucket is not pre drilled with holes but I still thought that was kind of high. ill have to check around. Thanks again.
/ Cutting edge for b21 #4
its a pain in the butt to install the edge on a non-drilled bucket. What they are asking may not be too unreasonable.
Frankly, you can almost buy a new bucket for the expense you'll go though. Why bother?
/ Cutting edge for b21 #5
Whats wrong with buying a good sturdy over sized cutting edge and having it welded on. It will stiffen up your bucket and probably never need replacement?:D
That happened to my B7100 bucket when the original wore out.:D
Thanks, for all the info. Ill look into it.
/ Cutting edge for b21 #7
Unless you are working with your loader continuously on concrete or asphalt conditions; a bolt-on cutting edge is a waste of money, plus additional weight. I have a 30 hp. tractor for 30 years with the original loader bucket for gravel, sand, and soil conditions, and occasions on concrete/asphalt. It's still in good condition. If you plan on pushing/removing snow on a hard surface; it maybe worth while? Consider you usage before spending your money, and common sense with the leading edge on hard surfaces.
/ Cutting edge for b21 #9
If you have a welded on edge a welding shop can easily hard face it to stop it from wearing. Worn edges can be built up if not worn into the bucket.
/ Cutting edge for b21 #10
mopar3500 said:
Good advice, Thanks:D
Maybe another point of interest? If you decide in the future with your B21, to add a tooth bar for grading, leveling, and etc; that would require removing the add-on cutting bar to use the tooth bar, which would be a (PITA) to me.
That B21 is a good tractor, and very capable of a lot of work!
/ Cutting edge for b21 #11
I believe if you check into the cutting edge it is just like the B26 and is double edged so when one side wears you can just remove and turn it over. That is one reason the cost is so high for installation as the holes have to be perfect so it will fit in both directions. :) The Gotcha Man
Gotcha, I did try that and my dealer told me that the two buckets were different in size. I thought that they were the same but I might be wrong.:confused:
/ Cutting edge for b21 #13
mopar3500, I'm sorry as I may have confused you. I'm not sure of the size of the bucket for the 21. I do know the heavy duty bucket for the B26 is 60" and the medium duty (standard is 66"). What I was mainly referring to was the bolt on cutting edge. It is beveled on both sides so that it can be turned around when one side wears you can bolt on the other side. As said in another thread if you plan on installing a tooth bar you will have to remove the cutter bar as the mounting bolts get in the way of the pre-manufactured bars. :)
The Gotcha Man
I have no use for the tooth bar but I appreciate the measurements on the buckets . Thanks
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
1996 MACK MIXER (A65643)
1996 MACK MIXER...
2017 TAKEUCHI TL8 SKID STEER (A65053)
2017 TAKEUCHI TL8...
