Cutting asphalt to create a drain
   / Cutting asphalt to create a drain #31
Why not drill a hole or holes in the lowest spot and let it soak into the ground? You put a leak in it and it will leak.
   / Cutting asphalt to create a drain #32
^^^hole is best idea yet!^^^
So simple, a French drain.
When repaved they'd fix it.
This post was about brainstorming for options when the people you would normally hire don’t want the work. It was never about money though I don’t want to pay an exorbitant amount like the current dealer markup on a new truck.
You’ve given me some ideas. Thank you for that.
   / Cutting asphalt to create a drain #34
Punching holes through for water to seep under, settle and soften the ground might not be the best approach.
   / Cutting asphalt to create a drain #35
I agree, it’s like knocking a hole in the bottom of your boat to let the water out, not the best approach.
Informational Lot - Shipping (A55302)
Informational Lot...
2013 Kubota RTV-X900 4x4 Diesel Utility Cart (A55787)
2013 Kubota...
John Deere Miniature Decorative Truck (A55758)
John Deere...
40006 (A55788)
40006 (A55788)
2023 54ft Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54ft Hooklift...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
