Cutting asphalt to create a drain
   / Cutting asphalt to create a drain #1
SouthernSky
Deville, LA
2013 Kubota L3200DT
I have a large area in front of my home that was black-topped maybe 20 years ago. In the center of the largest area (where everyone drives and parks) there is now a 40’ long depression that collects water that becomes a pond until it evaporates. An overlay is not an option (without a complete removal of all the current blacktop) as that will cause water to drain the wrong way.
So I want to cut into the 3” blacktop from the lowest point over to where I can drain the water into a drain with pipe and have it flow to a ditch. Then backfill it with … not sure yet but we do have to drive over it.
If I use the tines on my box blade, it will likely break off huge chunks of asphalt, much wider than I’d want the gap to be (6” or so”). I’ve heard a trencher should not be used as the tar will gum up the trencher teeth.
What would be the best way to make a smooth cut in the blacktop?
   / Cutting asphalt to create a drain #2
Might want to consider renting a demo saw otherwise I think you are relegated to a concrete cutting service for a really clean cut.
   / Cutting asphalt to create a drain #3
I agree...rent a wet saw...I'd consider something like this of the grade would support it...:
   / Cutting asphalt to create a drain #4
An old carbide skill saw blade will work. It,s probably only 1-2 inches thick.
Thanks for the ideas. I will look into a rental later this week. I actually already have two drains and a hose but wasn’t sure the what was the best way to seal it after cutting it.
I appreciate it!
   / Cutting asphalt to create a drain #7
A skil saw with a masonry blade will probably get the job done. A gas masonry saw would make quick work of the job.
   / Cutting asphalt to create a drain #8
A diamond blade is the blade of choice...
as soon as other toothed or composite etc. blades get gummed up they will only continue cutting while the asphalt is above it's melting temp...
   / Cutting asphalt to create a drain #9
I recently repaired an area of asphalt that was raised by a tree root that had grown under a driveway.
like others, I just used my circular saw with a masonry blade I bought at Lowe’s. I screwed a 2x4 into the asphalt (on the side that was to be removed) for a guide for the saw, worked great. The asphalt on the drive was less than 2” thick. The damaged area was close to the garage, after cutting and removing asphalt and root, I poured concrete as a repair. I was lucky that it looked like it had always been like that (concrete ramp to the garage).
Mike
   / Cutting asphalt to create a drain #10
How much length? If you're real careful removing the sections after you slice the path, you might be able to put them back in place and use some drive way sealer to fill the voids.
2017 Ford F-150 (A46008)
2017 Ford F-150...
Kivel Dual Prong Bale Spear w/ Back Frame (A45788)
Kivel Dual Prong...
2015 FORD T150 HANDICAP ACCESSIBLE VAN (A43003)
2015 FORD T150...
8' Root Rake (A40783)
Informational Lot (A44787)
Informational Lot...
YANMAR VIO35-6A (A45046)
YANMAR VIO35-6A...
