Cutter blades
/ Cutter blades #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
I mow my pasture with a 10' Bush Hog heavy duty 3 point cutter..I've never sharpened or replaced the blades..I've never abused the cutter and never mowed anything except grass..The blades are not gapped up but neither are they sharp...Does anyone here replace their blades or sharpen them and how much difference does it make?
/ Cutter blades #2
I consider mine a brush hog, and if it cuts brush, the blades are good to go.
If I were trying to mow grass, I'd consider a finish mower or likely sharpen the blades. :)
/ Cutter blades #3
I have done it both ways. I have sharpened them finer than frog hair and I have run them for many years without sharpening them at all. If they give me a satisfactory cut on my pastures I leave well enough alone.
/ Cutter blades #4
One should not sharpen rotary mower blades razor sharp as the sharp edge will curl over and not cut grass well
/ Cutter blades #6
I sharpened the blades for my brother in law on his bush hog using the same pitch (about 45 degree angle) as factory. I put them down to a sharp edge but not necessarily razor sharp but just like a lawn mower blade. It sure made a difference in his cut. I was really surprised at the surface, not gapped up too bad considering all the rocks that have been hit with it. Those blades are definitely harder than lawn mower blades.
I need to do the same with my bush hog as all we cut is pasture grass and the occasional rock. It is just a bit more hard to handle since it weighs almost 2000 pounds whereas I lifted his with my B26 TLB.
/ Cutter blades
This cutter is also about 2000#'s and the blades have never been off..Should I remove them to sharpen them or can it be done while on the cutter with an electric hand grinder?
/ Cutter blades #8
Different ways to do it, but pick one that is safe for you.
I tilt mine up on its side with the FEL.
If I didn't have the FEL, I'd use a block and tackle and tilt it up against a tree or post.
/ Cutter blades #9
We got into some metal with our ten foot Woods DS1260 cutter this year and tore the blades up, so we replaced them, otherwise just a touch up every few years.
/ Cutter blades #10
I always sharpen the blades while they are on the cutter. Raise the cutter with 3ph to max height, put a block under the rear of cutter just to be safe and use an angle grinder to sharpen each blade. Only takes a few minutes. Removing the blades can be very difficult and isn't really necessary.
/ Cutter blades
That's what I'm thinkin..however does it really do any good to grind old blades or should they really be replaced??
/ Cutter blades #13
Even factory blades aren't that "sharp". They'll have a bit of an angle ground on them but the edge will be really blunt.
If you want them sharp, you'll have to grind them sharp.
/ Cutter blades #14
Agree. I've always had to sharpen even new blades if cutting field grasses, but let them blunt when cutting brush. Don't want a clean shear cut on heavier brush which sharp blades will give and possibly puncture tires. Blunt blades tend to break/splinter heavier brush with less danger of puncturing tires.
/ Cutter blades #15
Ironically, if you leave the blades on long enough, they will eventually sharpen themselves... I replaced the blades on a MX6 this spring that have been on there for over a decade.
/ Cutter blades
Wow! Is the blade on the left the replacement blade for the blade on the right? Notice the difference in length..
/ Cutter blades #17
Yep, that is a new blade. The other blades edge and length had been worn down considerably after 10 years of heavy use (and probably a lot of scalping). The cutting width was probably around 5 feet instead of 6.
/ Cutter blades
I'm thinking now I don't really need to change mine..They actually look okay except the corners have rounded off slightly..I use a Bush Hog 3210 and it has 4 blades..
/ Cutter blades #19
I sharpen mine left on the tractor
I shorten the center link on the 3 pt and raise it as high as it will go
put my jack stands under it and crawl under with my 4" 18 volt cordless grinder
does a great job and seem to use less HP
just make sure you have a couple of batteries fully charged
my :2cents:
/ Cutter blades
my :2cents:
I've considered doing that too but for the life of me I just can't crawl under my 2800# cutter...I think it has something to do with all I've seen in the last 40 years of police work..:)
2020 Chevrolet Tahoe SUV (A61569)
2020 Chevrolet...
PROPANE TANK CAGE (A62131)
PROPANE TANK CAGE...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2018 Toyota Tundra Pickup Truck, VIN # 5TFRM5F11JX133691 (A61165)
2018 Toyota Tundra...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVER (A62131)
UNUSED WOLVERINE...
UNUSED KJ 11'X19' ALL-STEEL CARPORT (A62131)
UNUSED KJ 11'X19'...
