cutter bar attach procedure?
   / cutter bar attach procedure? #1
ricky1
Southeast Ohio
Mahindra 5500,8n Ford
Anyone ever attached a Massey Ferg cutter bar to a 5500? I had it on an old ford and need to use this cutter. The bar had a flat bar connection on right side to control sway and lift, was wondering if anyone has any info or had the same idea? any forseeable problems I should be aware of? :confused:thanks!
   / cutter bar attach procedure? #2
Don't use that sway bar, as your 5500 already has sway links on your 3PH already, just adjust them to the amount of sway you want.
Thanks! also the lift pins were not long enough to clear the bars. changed those and made adjustments and have cut over 2/3 of field with no problem. Thanks again for the info!:D
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
4 BRIDGESTONE 11R24.5 (A50854)
4 BRIDGESTONE...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
