CUT vs Skid Steer loader
/ CUT vs Skid Steer loader #1
kcook
Platinum Member
MI
Cub Lawn Tractor
If bought a new Tractor/loader (Kubota or John Deere) or Skid Steer Loader (Bobcat) Skid Steer Loader for around 20k. After 5 years, 1000 hours of use and in the same condition which unit would have the better resale value and why?
KC
/ CUT vs Skid Steer loader #2
A lot of variables figure into an answer to that question. But it's a good question. Biggest variable is how they will be used. Assuming general clean up and landscaping work of a personal, noncommercial nature I would think it would work out about the same either way.
A well maintained, clean machine with low hours that has not seen rough service will bring a good resale price, in the right market, no matter if it's a tractor or skid steer.
/ CUT vs Skid Steer loader #3
Most likely the skidloader.
Better market for used thousand hourskidloaders IMO.
PS Why not buy a Deere skidloader?
/ CUT vs Skid Steer loader #4
Usually these questions are re: "which would work better for me - Skidsteer, or CUT," followed by a long list of intended jobs.
I think that I'd be more concerned with that, rather than which would have better resale down the road.
/ CUT vs Skid Steer loader #5
Good question, figure out what fits not what fits someone else later.
/ CUT vs Skid Steer loader #6
Good point. A lot of hours on the wrong style would blot out the difference in resale.
Questions about use, includes landscaping (moving rock and stone) clearing snow in the winter. Not for mowing. Renting some attachments (breaker, PHD, Tiller and other landscaping attachments).
KC
/ CUT vs Skid Steer loader #8
KC
Sounds like a tractor to me. Skidloaders do alot of turf damage unless its 4ws, and they are really digging machines (except the attachments). Tractor would be more multi-purpose. Evaluate your needs, that skidloader might end up sitting around more than a tractor would. In my case that would be true, and I use my machine for the same purposes you listed.
/ CUT vs Skid Steer loader #9
As always, it depends on supply and demand. Right now with the construction business in the dumps, used skid steers can be had cheap and there is little market for them. Part of that also depends on where in the country. In places where the housing market has totally crashed, you probably can't give away a ss.
Also, finding a new SS for $20K means the small end of the range and the resale market for those will be more limited than a larger machine.
/ CUT vs Skid Steer loader #10
right now the market for used skid loaders is the worst that its been in years. Machines are going for pennies on the dollar. No doubt, you'd be way better off with a CUT.
/ CUT vs Skid Steer loader #11
KC
Sounds like a skidsteer to me.
I have not found a place to rent 3pt attachments. I can easily rent skidsteer attachments though.
Having had both, I find a tractor more useful around home on a day to day basis. And, attachments for a 3pt type hitch are much less expensive if you do buy them.
I have access to a Bobcat S185, a pretty heavy duty machine(6000lb, 65hp). I can out dig, out load my CUT all day long with that skidsteer. But, for average stuff, I like my little Kubota.
I personally would get a tractor, and rent a skidsteer or tracked loader for major work.
/ CUT vs Skid Steer loader #12
I would say a skid steer would be worth more, but I think you will find they cost quit a bit more. Most skid steers are desinged more as a piece of construction equipment, where a tractor can do some things a skid steer can't, such as plow fields, mow etc.
Doosan GC25P-5 Forklift (A63116)
Doosan GC25P-5...
2022 Timpte 1420 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1420...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
Mini rock grapples (A61567)
Mini rock grapples...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
JOHN DEERE 4000SC TRACTOR (A63745)
JOHN DEERE 4000SC...
