cut open a propane tank
   / cut open a propane tank #41
Probably been close to 50 years ago, I Had a 1959 chevy truck with a leaking gas tank. Of course those old trucks had the gas tank in the cab with you so if it leaked you knew it. I took the tank off the truck and not haveing any money decided I would acet/weld the pin holes. I washed that tank and rinsed several times, and was scared to death that wasnt enough. I finally took a long pole and wrapped a rag around it and set the rag on fire, Put the burning rag right up next to the filler neck and whoosh, the tank took off across the driveway like a jet engine. Once the fire burn out, I fired up the torch and welded up the holes.
   / cut open a propane tank #42
No suggestions as to best way to cut a tank but this is a link to a company that makes some good looking pits and may give you some ideas.
Look here: Muskoka Fire Pits
Love their work!!! and IMHO very reasonably priced,,, getting me thinking of taking a road trip !
   / cut open a propane tank #43
Could also use a CO2 , class "C" fire extinguisher. Fill the tank and if you have a second person there, have them give an occasional secondary blast in the tank as you are cutting. The Carbon Dioxide displaces whatever the atmosphere is in the tank. I would do this as your last step, after purging with compressed air first. Also used this method to weld on a 3/4 full diesel fuel tank on a truck. Worked great.
   / cut open a propane tank #44
To Dutch 445 . Muskoka Fire Pits were at the Toronto Cottage Life Show near the Toronto Airport last Spring. If they are back there this year it would save some traveling time to get one there.
RW
   / cut open a propane tank #45
Interesting, will look into that!
thanks RW
   / cut open a propane tank #46
Can also do this with some dry ice in the tank. Will likely not work on the 3/4 full tank but have done it in empty tanks.
   / cut open a propane tank #47
I have a 500 gallon propane tank that I would like to make a wood stove out of. I have the use of a gas powered chop saw but I was always wondering how to do it safely. Thanks for all the ideas.
   / cut open a propane tank #48
With the 500 gallon one, I'd go with full of water. Score the cut line without breaking through, then plunge and it'll pee all over you for less duration.
   / cut open a propane tank #49
You always have the best advice... and simple to do.
Much cheaper than flooding with Nitrogen...
Thanks, Curt
With volatile flammable liquids and fuel gases, forced-air venting works very well. I
have done it numerous times. When doing a gasoline tank, I hate to put water in
there.
With flammable oils (diesel, hyd fluid, etc.), it is already hard to get ignition because
oils do not vaporize readily. You need to make an aerosol of them to properly get
a stoichiometric mixture. Have you ever tried to light a bucket of diesel fuel on fire
with a match? Not so easy.
Sometimes, I cut hyd cyls with the plasma cutter, and they have residual oil in them.
Never started a fire that way.
One way you COULD get a fire is to cut into an oil tank that still has some liquid in it,
and run the torch flame INTO the liquid, which would aerate it. I have NOT tried that.
   / cut open a propane tank #50
I was reading a post on moving a propane tank.
Got me to thinking. How could I cut it open and make a fire pit out of the end caps.
Some information.
[video]http://www.business.govt.nz/worksafe/information-guidance/all-guidance-items/hot-work-on-tanks-and-drums/hot-work-tanks-drums.pdf[/video]
Here's a video of welding on a C3 tank. Sorta a
"How Not To Do It".
Don't think the fellar can weld either. Don't think he's got the right type of 90 there either.
2022 KUBOTA SVL75-2 SKID STEER (A51242)
2022 KUBOTA...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
Stihl KM 130R String Trimmer and Edger (A49461)
Stihl KM 130R...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
Heavy Haul Lowboy Equipment trailer (A49461)
Heavy Haul Lowboy...
