cut open a propane tank
/ cut open a propane tank #21
Thanks!
2 tanks, a section of diesel exhaust pipe and some other aluminized drops I scrounged from an exhaust shop, some channel, plate, flat stock, and a lot of electrode. :) Never did get around to putting the latch on it, but I have the spring knob for that.
I ended up extending the stack a bit since it didn't draft well that short. I've been planning on putting this in a deer stand someday - still haven't built the stand yet either. :eek:
That would be one nice deer stand.
I had a friend who built on 16 ft high with tv couch coffee pot.
I may have to look for another tank and build something like that.
/ cut open a propane tank #24
I had plasma'd off the top end on several of these a number of years ago for making into little vertical oriented stoves and just never did it after my prototype with charcoal failed to produce any appreciable heat for the amount of fuel I had in it. So I took a pair of those for my donors and mated them up. I used the open end of the tank I cut the radius'd shoulder off to mark where to cut the one to fit inside it and leave a minimal seam. You could cut these to make a butt joint, but the lap is easier to align and holds itself from warping when you put the final weld in.
The two tanks together allows for 18" front to rear depth, so it'll hold a 16" split. Just need to get a little fire started in there and then add bigger wood. What's nice about the design is that you can dry your wood on top before feeding it if it's a little wet.
I also added some vent holes to the bottom and boxed in the air path with the intention of adding a gate to control the fire and a sweeper to pull the ashes out with, but found that I get a better burn varying the door's opening and leaving the bottom vent wide open. Probably an issue of too much fire for the firebox volume - but it still works.
I was lucky in scrounging a whole mess of these tanks (had over 30 at one point) back when the OPD valves were being phased in and no one was converting the old tanks so people just tossed them or gave them away. Now I use them for all my waste motor oil and store it to dump on my brush piles for accelerant. :)
"Now I use them for all my waste motor oil and store it to dump on my brush piles for accelerant. "
Shame on you; the Politically Correct police are going to shake their fingers at you, and they will look down their nose's at you, and they will talk about you.
/ cut open a propane tank #26
I'm actually going to design a sprayer that uses a Schrader valve to pump the headspace with air pressure and has a dip tube to allow me to squirt my fire from a safe distance using the already full tank of oil. :)
/ cut open a propane tank #27
A propane torch also helps burn off the mercaptan residue and neutralize the stink. Plasma cutting does wonders as well. I've never found a remedy that'll clear it out better than fire though. Even after years, that dose remains in the tank with the valve off. Just remember that if you're going to use one for an air reservoir (they work great for them btw). Your air will stink for a long time unless you cook that stuff out first.
That is my experience, too. Cursed with a sensitive nose, I really want to eliminate that stink.
For LP or gasoline tanks, as well as 55gal drums, I remove all caps and ventilate with compressor air
after removing liquids. With 2 holes, I can blow in one, and ignite the exhaust from the other, using
a propane torch. If there are flammable gases, you get a flame. Stop the air when the flame dies
out. No woof or explosion. Works like an O-A torch. No water.
/ cut open a propane tank #28
You always have the best advice... and simple to do.
Much cheaper than flooding with Nitrogen...
/ cut open a propane tank #29
They can only explode if they're sealed and able to make pressure. Worst case scenario is you get a little flame thrower off the bung until the fuel is burned off with an LP tank. Other substances like your resin are a different animal.
I'll say it again - drain the tank down, remove the valve, then you can deal with the residual gasses. Always, always, always, always take the valve out first. You can fill it with water if you want, but it's been my experience that gravity does a good job.
Maybe I missed it: If you're going to use it as an air tank, how do you "cook" the smell out first?
Like another poster here that has done it, I plan to repurpose several 100 lb propane tanks as air tanks. I really don't want to deal with the smell but I really, really don't want to deal with an exploding tank. "Cooking" a former propane tank seems to be a lot like the latter.
Thanks
/ cut open a propane tank #32
Bernie: there have been a lot of deaths from exploding barrels and tanks.
General note: in an industrial setting one will find some pretty specific guidelines about what can be done with discarded containers.
/ cut open a propane tank #33
/ cut open a propane tank #35
There are places and times the nitrogen gets delivered by trailer trucks and requires a pump truck to get it into the system.
/ cut open a propane tank #37
Flushing it out with water won't remove the mercaptan. You can have it filled to the brim, dump it out, fill it again, dump, fill, dump, fill, dump = still smells!
/ cut open a propane tank #38
No suggestions as to best way to cut a tank but this is a link to a company that makes some good looking pits and may give you some ideas.
Look here: Muskoka Fire Pits
/ cut open a propane tank #39
I once picked up some staledated 100lb tanks and needed compressed air storage as my pump is a little small. I pulled the valves and vented in the sun, filled with water etc, then welded on extra legs for stability and height, plus a 1/2' pipe coupling for a drain in the bottom. Next I filled them with cold water and screwed a pressure gauge, ball valve assembly into the top while it sat out in the sun. I added a bit of extra heat to bring the pressure up to 300psi. Result was an air tank to hold 125psi that had been tested to 300psi,
/ cut open a propane tank #40
I've never done it myself. I've read where people wash the tanks out with soap and water. Then plumb the exhaust from a diesel engine into the tank while cutting. A lot of people say never to use the exhaust from a gas engine.
I have filled a gas tank with mig gas before welding on it. I don't know if it was the right thing to do or not but I'm still alive.
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
FIXED FIFTH WHEEL ATTACHMENT (A65643)
FIXED FIFTH WHEEL...
Mayrath 10" x 34' Truck Auger (A66285)
Mayrath 10" x 34'...
(4) 25' Texas Built Stand Alone Livestock Panels (A66408)
(4) 25' Texas...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP73V67X124782 (A65563)
2007 Ford Crown...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
