Cut Oak Boards
/ Cut Oak Boards #1
bindian
Super Member
Willis, Texas
Mahindra 6520 4WD
I have several large oak trees that I will be cutting and taking to a one-man sawmill to be cut into fence (corral) boards. Is there any oak tree varieties that do not do well cut for fence boards? How long do I dry them before nailing them to the posts? :confused:
hugs, Brandi
/ Cut Oak Boards #2
hugs, Brandi
Mornin Brandi,
Your probablly better off nailing the boards while they are still wet ! Once they dry you usually need to predrill the boards to prevent them from splitting on the ends. ;)
/ Cut Oak Boards #3
Brandi,
White oak varieties weather better then red oak, so it would be good to know what kinds you're cutting. (Sawmill can tell you and/or separate the boards out as they cut)
Otherwise, you can nail them up as soon as you get them home -- wet wood is heavier, but also a bit more pliable so less likely to split.
If the sawmill will dry them for you at a reasonable price, you could give them a coat of boiled linseed oil before nailing them up - which will help preserve the color of the wood and slow down the rotting - drying also gets the shrinkage out of the way. If you don't oil them, they should still last several years, so long as they're not constantly wet.
good luck!
/ Cut Oak Boards #4
You might want to go over to Forestryforum.com and do a search. It's been discussed many times.
/ Cut Oak Boards #5
Oak degrades very fast in the weather. You will need to treat the wood as soon as possible. I have tried to use oak for some outdoor projects and just requires too much maintenance.
/ Cut Oak Boards #6
I don't know about that. I know of miles of fence in Va. which are thirty years old and going strong.
Locust post and oak rail.
/ Cut Oak Boards #7
White oak......you need white not red
Kevin
/ Cut Oak Boards
Kevin[/QUOTE
Since I use red oak for great splittin' :) firewood, I will go with the white oak for fencing. My uncle has 3 inch think boards (beams) for his cattle corral boards. They have been there longer than I can remember. Thanks guys for all the input. :D
hugs, Brandi
1995 PONDEROSA 16' STOCK TRAILER (A64278)
1995 PONDEROSA 16'...
2017 Ford F-550 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2017 Ford F-550...
46200SFL (A64557)
46200SFL (A64557)
2018 Ford Focus (A61574)
2018 Ford Focus...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
