CUT Cup holder
/ CUT Cup holder #1
wvhillbilly
West Virginia
Kubota L3400
Hey ya'll,
It hit me like a ton of bricks while out in the barn today. All summer long I have been on a quest for the perfect cup holder for my CUT. As I was cleaning out my barn, I uncovered my old mountain bike from my earlier "in-shape" days and there it was, staring back at me. So, for all you who may be on the same quest as I was, Go to your local bike shop and buy one of those wire cage bottle holders. It works great. They will (or at least mine does) hold a 16 ounce coke bottle perfectly...
/ CUT Cup holder #2
I like it.
Simple, easy, cheap, adaptable to different liquids.
What more can you ask. /forums/images/graemlins/cool.gif
/ CUT Cup holder #4
This was my solution. See attachment. Gerard
/ CUT Cup holder #5
Here is what I did. I made mine magnetic so I could easily move it to the other tractor, or take it off when I want to.
I used one of those cheap stainless steel magnetic trays. The ring magnet on the bottom of the tray provided a place to drill a hole, and let me attach a wooden disk to the tray with one screw. I attached a piece of 4” PVC pipe to the wood disk, and put a piece of rigid foam insulation in to help keep things cool.
A second piece of pipe (had a piece with the expanded end on it laying around) slips over the base piece, gives me the option to have a shorter holder in the future is I should desire to. Doubt I will want to though.
This photo has a second parts tray sitting on the concrete block, showing the starting point. Actually I think it was holding a screwdriver bit.
/ CUT Cup holder #6
It sticks to the fender real well, but I suppose a branch could strip it off. I have not had any problems along those lines though. Water bottle is 1 liter in size. Nice amount and stays cool for a rather long time on a hot day. Of course, on a hot, thirsty day, the water does not stay in the bottle very long!
/ CUT Cup holder #7
It will fit on either side, but I generally keep it on the left, as the position control lever is on the right.
/ CUT Cup holder #9
Almost forgot this one. Gerard
/ CUT Cup holder #10
Gerald you beat me to the punch on that one. There have been many times while working with my backhoe that I really wished there was some way to hold a drink to quench the thirst. If I set it down by my feet sooner or later I always knock it over before I get a chance to drink. So I guess that will be one more winter project right after I convert my manual rotating chute on my snow-blower to a hydraulic motor. Thanks for the idea. /forums/images/graemlins/grin.gif
/ CUT Cup holder #11
</font><font color="blue" class="small">( If I set it down by my feet sooner or later I always knock it over before I get a chance to drink. )</font>
That's exactly why I had to put one on the BH. Spent more time cleaning up the spill (gets sticky) rather than making progress. Gerard
/ CUT Cup holder #12
I found a cup holder made for boats called a Bar Bouy. I used an existing hole in my loader frame and installed it without drilling any new holes into my tractor/loader. Here's a pic cup holder
/ CUT Cup holder #13
Blackjack I really like that swivel feature on your cup holder. With that one if you roll the tractor over you won't loose a drop of coffee in the process. /forums/images/graemlins/grin.gif
Be careful out there.......
/ CUT Cup holder #14
Blackjack,
I have the same type of thing on the fender of my old IH 2444, works great.
For other uses ie Riding mower,etc, I just hot glued flexible magnetic strips to the bottom of soft foam huggies, works great on anything metal.
Ben
/ CUT Cup holder #15
Sounds like a great idea with the magnetic strips. These days it hard to find much metal on the newer CUTs!
/ CUT Cup holder #16
sure that would work, but not on a corona bottle! /forums/images/graemlins/grin.gif
/ CUT Cup holder #17
<font color="blue">For other uses ie Riding mower,etc, I just hot glued flexible magnetic strips to the bottom of soft foam huggies, works great on anything metal.</font>
I use silicone (see attachment). Gerard
/ CUT Cup holder #18
For the corona bottles, I have a zip up huggy for bottles I have rigged the same way. Works good for all drinks, but I don't drink and tractor /forums/images/graemlins/smile.gif
/ CUT Cup holder #19
This is behind the times /forums/images/graemlins/shocked.gif
Do a search for the "Chalkey Cup". There was major innovation here on TBN about 3 or 4 years ago. Mark, and HARV, and a few others engineered the most impressive cup to be placed on a tractor.
Here is a link to some pictures.
www.fieldlines.com/other/chalkley.html
