Custom Tractor Canopy
/ Custom Tractor Canopy
Going to take some photos in the morning. Got the radiator fan in this morning (reversed the fan blades to blow are out instead of sucking it in)
Worked on the led pod placement and wiring to the 6 gang toggle switch box.
Took some photos of the tractor as well. Looks to have a few good spots to mount the top to the ROPS and frame using existing holes and mounts. IMG_20210220_140438.jpgIMG_20210220_140438.jpg
/ Custom Tractor Canopy #12
Coming along nicely.... last fall, I mounted mine (plain Jane) Used basically the same mounting holes... I parked under my deck, use "C" clamps to anchor straps to support the roof while I fabricated the braces and mounting brackets.
Thanks for that. That's exactly what I sketched out to mount the support bars. Hoping to get everything wired up this week and tested and get it mounted this weekend, weather permitting.
The layout so far. Going to wire everything up tonight hopefully to do a test on the connections etc. Got to find an extra battery in the garage to hook it up to.
/ Custom Tractor Canopy #15
Looks great. Keep up the good work so the rest of can steal shamelessly. Kidding but not really.
I could not find specs for your alternator... is it going to be strong enough for that load?
I will only be running the stereo and fan during day light and the lights by occasion.
I do have a voltmeter on the toggle switch gang to monitor it. I believe the alternator is 60amps
/ Custom Tractor Canopy #19
IMG_20210224_193341.jpg]
Not going to lie... This thing is the bomb. The fan is crazy powerful and the stereo is loud AF. Lights are super bright and I have them each on their own rocker switch to keep voltage low.
Next step is fiberglass then paint and reconnect and test, then mount. IMG_20210223_163916__01.jpgIMG_20210224_160442.jpg
Got a lot done today. I'm still "new" with the tractor, but learning a lot and I'm impressed with what this tractor can do especially in how mucky this land is.
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
24in pin on excavator tooth bucket (A61307)
24in pin on...
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2020 MACK P164T (A60736)
2020 MACK P164T...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A60736)
2008 TEXAS BRAGG...
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
