Custom Tractor Canopy
/ Custom Tractor Canopy #91
Got all 4 led lights installed & radio antenna & both side braces for forward center bar witch will hold the radio & rocker switch for main harness & that will be mounted tomorrow so all have left to do after tomorrow is all the wiring & I'll follow up with pictures tomorrow is was to late for pictures today.
Here are the pictures with everything installed & all that is left is the wiring(y).
IMG_20210704_113317.jpgIMG_20210626_174519.jpgIMG_20210704_102257.jpgIMG_20210704_102333.jpgIMG_20210704_102402.jpgIMG_20210704_102435.jpgIMG_20210704_113317.jpgIMG_20210704_113348.jpg
/ Custom Tractor Canopy #93
I know, I was giving some feedback on a basic Golf cat top as an option for a canopy to save $$$ from a flimsy cheap plastic canopy.
If I wasn't going to do the lights and stereo, I'd do a golf cart top again with the bed liner. Looks great and it's a great cheap option
Hey SaintPe ! Did You get your golf cart top mounted :unsure:? Hope it's going okay with mounting it(y).
/ Custom Tractor Canopy #94
Nice job.
Thanks Mrsig! I'm going to do the wiring to the led lights 1st & I've got to mount the rocker switch 1st next to the right of the radio & I'm doing the radio last & the radio was the most expensive item on the hole build & actually cost more than the whole build.
/ Custom Tractor Canopy #95
Has anyone thought about using a rain cover with there golf cart canopy? Seems like it might work ok for wet work!
/ Custom Tractor Canopy #96
Hey looks good on a golf cart , but on a tractor when it's hot & you need to get off & on just not practical & I've seen those canvas cabs before no thanks, I'd rather have a real cab a/c, defroster & all the other goodies that come with a full cab, But I do like those mirrors ( light bulb! ) & they would look good on my forward side braces
/ Custom Tractor Canopy #97
It slips on over the top of the canopy. I would only put it on for bad weather. I did not spend an extra $9000 for a cab so I guess I'll just have to deal with a $150 removable cab.
/ Custom Tractor Canopy #98
Yea I see your point, & I have a cover that came off the front of one those portable garages & covers the rest of the tractor front to back as well the sides, The portable garage got crushed during a heavy wet snow storm that was at least 2 feet deep & the framing was all mangled(n). But I'm going to check into those mirrors.
Been rained out and working every day. (floor cleaning and restoration business) lots of floods have kept me from having any spare time to install it. Need a good sunny day to mount it
/ Custom Tractor Canopy #100
Okay thank You for the reply & I hope You get the weather You need for the completion & You all sure could use a break on all the liquid sunshine You've been getting. I still have not completed the wiring yet on mine even though I did get a little done on it.
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
KUBOTA L3301 TRACTOR (A62130)
KUBOTA L3301...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2014 Dodge Avenger Sedan (A59231)
2014 Dodge Avenger...
2008 Ford E-250 Cargo Van (A59230)
2008 Ford E-250...
