Custom High Flow Kit
/ Custom High Flow Kit #1
Schwartz04
Does anyone know where I can get a hold of a high flow kit for a takeuchi Tl150 I am trying to see how expensive they are?
Thanks
Adam
/ Custom High Flow Kit #2
That is exactly what Supertrak does, is install a high flow pump and add/increase the cooling capacity of the tractor. The kicker is knowing where to get the pump and hardware to install. It might be easier to what till Tak comes out with a high flow themselves and figure out what to do that way. Because I doubt supertrak will willing give you that info. They will happily sell you a tractor with high flow. But, a Rexroth pump is a Rexroth pump!!!
Yeah I knew supertrak sold them but I was wanting to find out if I could basicly do the same thing a little bit cheaper. But I cant find anything about it.
/ Custom High Flow Kit #4
Maybe you could get your eyes on a TL150 that has the high flow pump and just look to see what exact pump brand and model is installed on it? Then turn around and order yourself the pump.
Then you still need to worry about the cooling issue, but you can always order yourself a larger capacity cooler too.
/ Custom High Flow Kit #5
Since Gehl has a high flow and they are Takeuchi's why not look into getting Gehl parts?
Takeuchi (us) has not released a high flow because they feel it runs the motor too hot.
/ Custom High Flow Kit #6
Gehl and Mustang mount an additional pump out on the engine and combine flows with the standard aux pump to get their flow.
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
Lifts (A61567)
Lifts (A61567)
2011 Polaris RZR 900  (A62679)
2011 Polaris RZR...
2022 EZ-GO ELITE...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
2018 Kenworth T680 (A64127)
2018 Kenworth T680...
