Custom cut pieces?
/ Custom cut pieces? #11
Frederic,
Thanks. I think that you have posted this information before but I did not connect it. Thanks a bunch for the info. I have most of what is needed except for the cutter and the motor guard filter. Trying to justify the expense in my mind.
Farwell
Thanks for the input on the plasma cutter frederic. My buddy has a fairly new one at his shop that we use from time to time. While it works well, for me, it seems to be a little tricky to use. For example, when cutting a piece of steel, say 1/4" mild sheet, it'll stop cutting in the middle of "the run". Then I have to release the button, press the button again and continue cutting. I'm not sure if it is the machine or me that is causing the problem. Before each cut, I spray the tip like the instruction manual says. The one thing I'm not clear on is how far above the piece do I hold the nozzle? Should it be just above or in direct contact with the steel while cutting? Any help would be great.
Ryan
/ Custom cut pieces? #13
Or the other option, using compressed nitrogen. No driers needed. Doesn't miller have a paper filter that looks like a roll of TP to attach to their units?
/ Custom cut pieces? #14
</font><font color="blue" class="small">( Doesn't miller have a paper filter that looks like a roll of TP to attach to their units? )</font>
That's a Motor Guard filter.
/ Custom cut pieces? #15
Hey guys.... happy to help. A plasma cutter is a big expense, and not for everyone. For me it was time economics. Every project I embark on requires a tremendous amount of cutting of metal, so why spend 40 minutes watching a hole saw bore it's way through 3/8" steel (slowly, as not to rip the teeth off) when I can zap a circle with a plasma cutter in about 3-5 minutes?
As far as what else you need... the 375 is simple. 220V input, compressed air (through a moisture capture unit and a filter of course).
If you want a beautiful cut you can feed it argon or another noble gas if you wish, however to my brain this defeats the purpose of the plasma cutter - cutting without having to refill large tanks. Oxy/Acl cutting is just as easy, except you have to refill your tanks quite a bit.
Sorry I haven't been keeping up lately... been working on a new project:
I just started, so it doesn't look like much. Essentially it's an open-frame combination of X and Y trucks, that will eventually have my plasma cutter gun attached, and controlled by a cobbled together PC.
The software works, the homemade stepper interface works, and the X and Y trucks slide freely. What's next is to buy Nema23-sized stepper motors, slap together some cog-pulleys and belts, and build limit switches.
/ Custom cut pieces? #17
<font color="blue"> you can feed it argon or another noble gas if you wish </font> According to the book I got, nitrogen was the only choice given. What would be the difference between argon and nitrogen? <font color="blue"> defeats the purpose of the plasma cutter - cutting without having to refill large tanks. </font> Our field service crew thinks bottled is easier than getting another compressor. I almost have to agree with them, it's my money they're spending.
SANY SY50U EXCAVATOR (A59823)
SANY SY50U...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2019 FORD F-250 XL EXT CAB TRUCK (A59823)
2019 FORD F-250 XL...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
