Curtis Cab 2X20
/ Curtis Cab 2X20 #21
We had a significant increase in volume in our BX2660, perhaps 2x, but I dont think it was 5x.
I think that sealing the transmission area from the cab (including around the levers) and putting something on the roof would work wonders.
Aaron Z
/ Curtis Cab 2X20 #22
yeah, sorry 5X may have been a bit of an exaggeration. but she is loud, especially with the mower engaged.
/ Curtis Cab 2X20
Aaron Z
Sounds like I can live with that let alone make some soundproof improvements as I go.
Will pull the trigger tomorrow. :thumbsup:
/ Curtis Cab 2X20 #25
I have been shopping this arena too. Have been on and off a 2920 at my local dealer so much I think he wants to charge me rent.
Wish he had one with a Curtis cab so I could see how my fat *** would fit in it, but the work platform in this model seems real
generous for a small tractor. I had to move the seat forward a scooch to be comfortable.
Was pricing one up today with the deluxe overhead console but would it be to loud in there to listen to the radio anyway? I will be pushing with a front blade.
I was looking at the next frame size up 7800,2910 etc. but am not sure that it has as much room as the 2*20 series.?
/ Curtis Cab 2X20 #26
Skeetman,
For me, the noise inside the cab on my BX24 is too loud to not wear hearing protection. However, I have to offer a few caveats. My cab is the hard side model so I suspect the amount of resonance is higher than that of the soft side model. My hearing is still very good (never went to rock concerts) so I am perhaps more sensitive to noise than others. If I had a radio playing I would still be able to hear it in the cab but do not expect it to be like listening to the radio in the car.
That being said, you are not without options. As others have suggested, additional soundproofing should help. When I work in the cab I wear the 3M Work Tunes hearing protectors (Northern Tool #1746366 ). It has a built in radio and a jack to connect it to my MP3 player. I can't hear any outside noise when I use these. I could not tell from the picture online but you might want to see if the Curtis Deluxe Console has an output jack that you could connect to the Work Tunes.
Regardless, I would not let the cab noise stop me from buying a cab. The reward of not being blasted by wind and blowing snow is just too great to not put a cab on the tractor. Plus, with the cab you don't have to worry about brushing snow off the seat to avoid a wet butt.
/ Curtis Cab 2X20 #27
minnebota does your BX24 fit into a garage with the cab on?? I know its lower than the roll bar. I would like a cab but was worried about fitting it into my garage. Do you have a height measurment??
Jim
/ Curtis Cab 2X20 #28
/ Curtis Cab 2X20
Skeetman,
I sat in a B2X20 which was having a Curtis cab installed (see pic from my 1st post here) my impression is that there is a LOT of room (yes the heater does project out some) but overall when you are in the seat I find the entire cabin very roomy.
As for the overhead console and radio since I do not own one of these yet I have read that the Radio does get washed out with the noise from the tractor and the cost of the overhead console is not the best return on the investment.
I too sat on the 7800 / 2910 and 3030 series - much larger TRACTOR platform and the seat is lower between the rear tires (where as the 2X20 you sit much higher) BUT i found the floorboard of the 2X20 is as big if not bigger than the lager frames.
~jim
/ Curtis Cab 2X20 #30
Jim
Yes, my BX24 fits in the shed with the cab on. I have an 8 foot door on the shed with an opening height of 94 1/2 after trim. The BX24 ROPS height is about 85 1/2 as best as I can measure it (with turf tires). The top of the cab is at about 78 1/2 with the roof in the locked position. In case you have not seen it, the BX24/25 cab has a hinged roof that allows the top to lift up in the rear. This gives more headroom when using the backhoe. In the lifted position the rear of the roof is about even with the top of the ROPS. (all dimensions in inches)
I'm going to try to anticipate the next question. Can a BX24 with a cab go through a 7 foot garage door if the ROPS is folded? With trim, the 7 foot door probably has about an 82 1/2 inch height. At 78 1/2 inches the cab should go through with the ROPS folded. Yes, I do think the ROPS can be folded with the cab on. The upper two brackets that brace the cab to the ROPS are U shaped that fit around the ROPS with a rubber padding that provides a friction fit. There does not appear to be anything that would prevent the upper section of the ROPS from being pulled out of these brackets as it is being folded down.
All of this is based on my installation. I would encourage anyone considering this to verify with their dealer or the manufacturer that this is still and will be the case if they purchase a cab. How's that for a disclaimer?
/ Curtis Cab 2X20 #31
Hey all - good info once again but this has got me a bit scared - 2X I could stand but 5X! is it really that bad? You wont believe why I am asking - I ride with our dog - yes he freaks if he does not come with me - if its that loud I just may have to pass and put on the Carharts - and yes he has a pair as well.
Pathetic is an understatment.
Seriously - I would like to know if most experiance this large increase in noice volume.
Thx
I built a hard cab for my L3000DT this past winter, yes it is loud. I bought a 50 dollar head set with built in radio which I simply hang on the loader valve when not in use.
My dog rides in the cab with me all the time and loves it noise and all.
/ Curtis Cab 2X20 #32
I have a Curtis cab on my 99' B2710. I got the cab used last fall and it was already together in one piece. My son and I were able to just drop it on and bolt it down. I did have to remove the ROPS, as I couldn't get it high enough with the cherry picker we used to lift it. I think if you could raise it straight up you could remove and install without too much trouble. I did put in the heater that came with it and added the 40A alternator for the extra lights and heater fan. I have the hard back with extra wiper and soft sides. This was the best $1800.00 I have spent for my tractor! Last winter we had tons of snow, and running the front blower wearing just a sweat shirt sure beat bundling up with coveralls and ski goggles for sure! What I did for the summer mowing season was remove the doors and windshield, which is very easy to take out. This gives you all the air you need and leaves the top for a sun shield. Will be putting the windshield back on this weekend, as it is getting colder out there, and will cut the grass the last few times with the cab closed up.
/ Curtis Cab 2X20 #33
Man, I'm really getting tempted.....
minnebota, what did it set you back to get the Curtis for your BX24?
/ Curtis Cab 2X20 #34
Golfaddict
The Curtis hard side cab for the BX24/25 ran about $3800 including tax and shipping. Since you are also in SE Minnesota you could talk to one of the guys over at St. Joseph equipment in Eyota. That's where I purchased mine.
Which tractor model do you have?
/ Curtis Cab 2X20 #35
Golfaddict,
Sorry, I just checked your profile and it looks like you have the BX24. If you get the Curtis cab it will install very easily with only one exception. The cab was designed for the BX25 which has metal fenders. On the BX24 there was a modification that most have installed that added a reinforcing step bracket under the floor pan to keep the plastic fender from cracking where it meets the floor pan. Because of this bracket the Curtis supplied bolt that connects the left side frame to the floor pan is too short. This is just one bolt and it is easy to buy or scrounge one that is longer. Not a big deal since the rest of the cab fit, alignment, and installation was without a hitch.
/ Curtis Cab 2X20 #36
Thanks minnebota!
I do business with St.Joseph's also, just got the grass catcher from them this summer - spendy, but I'm quite happy with it.
For $3800 I'll have to really think about it. I haven't used my BX24 much in the winter, just to push back snow banks with the FEL when I had to. I am thinking of converting my ATV snow plow for use on the FEL and if I do I'd use the tractor for regular snow removal and then a cab would sure be nice...
I don't think I'd leave it on other than winter. I have turf tires on mine, so when there are no attachments on (which is much of the time) it pretty much looks like a regular garden tractor on steroids. With a cab I'm afraid it would look like a cab on wheels running around. :laughing:
/ Curtis Cab 2X20
I went and looked at a Curtis Cab on a B series - I just dont see how they justify their pricing model that the Cab should be priced at 1/4 the cost of the tractor.
So, since my original post I have finally decided that $4000 was ridicules money to spend on a cab that especially that was going to be used only 4 months / year.
Now - if Curtis had a Summer Sizzler Sale (HINT HINT) with a blow out discount of 40% I just may reconsider - otherwise I love my Carharts and fresh winter air!
2024 Linx 7'X12' UT357714T (A60463)
2024 Linx 7'X12'...
MGY Shop Heater (A60463)
MGY Shop Heater...
2007 Capacity TJ6500T Wet Kit T/A Yard Dog Toter Truck (A55973)
2007 Capacity...
LMC Ag 3pt 300 Gallon 54' Boom Sprayer (A60462)
LMC Ag 3pt 300...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
150 Gallon Saddle Tank (A60463)
150 Gallon Saddle...
