Curtis Blade-FEL Hyraulic
   / Curtis Blade-FEL Hyraulic #11
Fred
Are you using the block connection block that Curtis supplies with their blades for power angle? Make sure lines are hooked up correctly. I'm not at my tractor this morning. This afternoon I can take some pictures to show proper hook up of hoses. Let me know how you make out.
Ron, I bi-passed the relief valve to make sure it wasn’t the problem. The information
Kubmech gave corrected the problem. I ran a few test and he is right. It looks like I will
need to install a aux. valve.
Thanks
Fred
Thanks Kumech for the information, I switched the controls again and made sure to connect to the correct end of the cylinder to test your information. It did as you stated. When I switched the first time I must have had the hoses switched. I could just switch the controls to use the blade and everything would work right except I wouldn’t have float control.
Thanks for your correct information. I also want to thank everyone who responded.
Fred
2025 CFG Industrial H12R Mini Excavator (A56857)
2025 CFG...
2018 KENWORTH T880 HYDROVAC (INOPERABLE) (A58214)
2018 KENWORTH T880...
2018 Ford F-550 4x4 Terex LT40 40ft. Bucket Truck (A56858)
2018 Ford F-550...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
2014 Dodge Journey (A55272)
2014 Dodge Journey...
2005 CHANDLER 500 BBL FRAC TANK (A58216)
2005 CHANDLER 500...
