Curtis Blade-FEL Hyraulic
   / Curtis Blade-FEL Hyraulic #11
Fred
Are you using the block connection block that Curtis supplies with their blades for power angle? Make sure lines are hooked up correctly. I'm not at my tractor this morning. This afternoon I can take some pictures to show proper hook up of hoses. Let me know how you make out.
Ron, I bi-passed the relief valve to make sure it wasn’t the problem. The information
Kubmech gave corrected the problem. I ran a few test and he is right. It looks like I will
need to install a aux. valve.
Fred
Thanks Kumech for the information, I switched the controls again and made sure to connect to the correct end of the cylinder to test your information. It did as you stated. When I switched the first time I must have had the hoses switched. I could just switch the controls to use the blade and everything would work right except I wouldn’t have float control.
Thanks for your correct information. I also want to thank everyone who responded.
Fred
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
2017 Mitsubishi Outlander AWD SUV (A56859)
2017 Mitsubishi...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2014 Volkswagen Diesel Passat Sedan (A56859)
2014 Volkswagen...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
