Curl cylinder on 8TL loader for bobcat 335 tractor nut removal.
   / Curl cylinder on 8TL loader for bobcat 335 tractor nut removal. #1
CKJ Farm
Bobcat
Anyone with experience in removing the aluminum nut on the curl cylinder of an 8TL loader? The seal is leaking and I have the kit to replace. I’m having trouble removing the nut on the cylinder. I even purchased a spanner wrench. I can’t seem to break it. Any suggestions?
Yes, very similar. Only two notches and the notches are only half way thru the nut which makes it nearly impossible to use the scanner wrench. I was finally able to break it loose with channel locks. Thanks for checking.
   / Curl cylinder on 8TL loader for bobcat 335 tractor nut removal. #4
Glad you got it. (y)
2018 DRAGON ROLL OFF TRAILER (A55745)
2018 DRAGON ROLL...
CAT GENERATOR (A55745)
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A55301)
Gooseneck...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
White Metal Roof Panels (A55758)
White Metal Roof...
