curl cylinder for vtek v2
   / curl cylinder for vtek v2 #1
woodcarver11
central Kansas
yanmar 1610d
Hello, I have a vtek v2 loader with a bad curl cylinder. I had it rebuilt but it only held for 10 hours. Would anyone know where I could buy a new cylinder for it.
   / curl cylinder for vtek v2 #3
You will need the bore, shaft, closed and open lengths in standard and metric. With those a good hydraulic store can get or make one. The standard vs metric is to ensure they both match.....and unfortunately they could be made to either standard depending on source.
If it is too tough and or expensive to find one that matches, you may end up with two new ones that are close.
Thats what I needed to know. I don't have a problem ordering a pair if needed. .Was hoping someone had needed to replace them and knew which ones would work.
Thank You
   / curl cylinder for vtek v2 #5
Is it in bad shape? I ask because the rebuild should last a lot longer than ten hours. Have you talked to the rebuild shop? Post a picture of the cylinder, maybe we can talk you through rebuilding it yourself.
It was leaking externally so I took it into a local shop. this was last summer. I am pretty bad with computer stuff ,I don't know how to post a picture. They fixed the external leak but at about 10hours after the repair it stopped holding the bucket curl.I checked and it is the cylinder that was repaired. Charged me $240 so I won't be doing business with them again.I would rather put a new one on then repair it if I can find one.
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53473)
2017 Yale GLC050VX...
1982 LeeBoy Motor Grader (A53473)
1982 LeeBoy Motor...
Truck Wheel Fenders (A51692)
Truck Wheel...
2025 CFG Industrial H15R (A50123)
2025 CFG...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53473)
UNVERFERTH 330 -...
