Curious about deck rings on flexwing mowers....
   / Curious about deck rings on flexwing mowers.... #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got this older Hydraulically powered 15' flexwing mower (Terrain King which is now owned by Alamo). Mower is powered by PTO driven speed increaser and a pump.
Debating on getting a newer mower.... saw a newer version of THIS same mower, now made by Alamo. The newer version has deck rings and mine does not.
Got me wondering.
When I cut with mine, the air/wind will blow through the hinges and I will have some grass accumulate on top of mower. I interpret this as the blade suction helping to pull the grass up and ejecting most of it backwards but some goes vertical. Leaves a decent cut. The field hasn't been cut since last summer and the sprouts were about belt high.
Are the deck rings on a mower strictly to act as a barrier between the blades and the deck or, do they also serve to create an air chamber to help improve the cut of the grass??
   / Curious about deck rings on flexwing mowers.... #2
My Large finishing pull mower was ALAMO. I thought they got bought out long ago. Is yours a finishing mower? Mine sounded like a GIANT Vaccuume cleaner and I'm guessing the sheet metal work directed airflow and provided suction for the grass being cut.
Alamo Industrial: Products
Mine is a 'bush hog'....or rotatary cutter. (in need of newer blades I might add)
Being hydraulically powered, I suspect mine is fairly quiet (as though you could hear anything above the noise of the IH 1066 screaming at PTO speed with no muffler)
I don't know that to be true about being more quiet.... I have just presumed that I don't have the additional noise of the rotating shafts that I might otherwise have.
I admit I kind of like the idea of no spinning shafts but I suppose the hydraulic part has its issues too.
   / Curious about deck rings on flexwing mowers.... #5
I bought mine at auction from a CITY. Found out the GEAR box cost $6000.00 if I had to replace it. Double what I paid for the whole mower. I would have prefered hydraulic drive so could use less than all the decks.
BIGGEST pain was 1/2 Reverse fine thread blade bolts that cost a few bucks each and I could loose several on ant or groundhog hills in a fifteen minute span. Ended up having bolts custom made in the US.
I've also been eyeballing a Schulte 15' however, before I knew too much about them, a dealer 3 hours away from me had a Schulte 20' get sold right as I was eyeballing it trying to figure out if I could stop it going down a hill. (my understanding is the highest spot in the county where I live, happens to be the hill my house sits on..... and the farm owns the entire hill)
I don't want to get manhandled by a mower going downhill.
in fact, those pictures above are of that very hill being cut. The pictures sort of hide the length. It's not terribly steep per se'.
   / Curious about deck rings on flexwing mowers.... #8
A friend had a new pull type hydraulic wing mower and his employee jack knifed it on a hill and caused the pump shaft to be pushed in at tremendous expense.
Must have really crunched things. Looking at how mine mounts, (adapter mounted to tractor, speed increaser attached to adapter, pump then attached to speed increaser)
I have a hard time seeing how someone could crunch that unless they really got folded in half. Ouch.
   / Curious about deck rings on flexwing mowers.... #10
I seem to recall something about the shaft being a little on the long side.
Tool Box (A47384)
Tool Box (A47384)
1267 (A50490)
1267 (A50490)
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
MODERN MANUFACTURING 8' DISC HARROW (A51243)
MODERN...
2013 Mack GU713 T/A Roll-Off Truck (A50323)
2013 Mack GU713...
2025 72in Rock Bucket Skid Steer Attachment (A50322)
2025 72in Rock...
