Culvert and landscaping question
   / Culvert and landscaping question #11
I’d make sure there is enough drop on a 40’ run to keep it from building up sediment and clogging. To clear a clog 20’ in will not be easy.
MarkV
   / Culvert and landscaping question #12
If you want to keep roots out of pipe; pull a piece of copper wire from one end of the pipe to the other end and attach ( bare copper) No roots will enter the pipe.
   / Culvert and landscaping question #13
I understand the copper wire thing, but will that work with a plastic culvert like he is using?
David from jax
MarkV said:
I壇 make sure there is enough drop on a 40 run to keep it from building up sediment and clogging. To clear a clog 20 in will not be easy.
MarkV
Good point, thanks....will make sure it is sloped properly.
   / Culvert and landscaping question #16
If your worried about tree roots then why not go with a smaller bush.
You can get different hedges and let them grow high enough to block or to make the landscaping look natural. Even think of berry bushes or ground covers to blend everything in. when i landscape around my house i make it as easy as possible. i look for plants and trees that need a minimal amount of pruning. I also look for perennials--they might need to be divided but thats a lot easier and cheaper then buying annuals every year. I have also put in bush cherry's and next year the blueberries. i have tied them into the landscaping and it makes things much easier, even when mowing around.
good luck,
dont forget your slope, and over plan for the amount of rain, water is very powerful.
forgeblast
   / Culvert and landscaping question #17
Well if the culvert upstream of you is 18 inch and the culvert down stream is 18 inch then use an 18 inch culvert. Otherwise you will restrict the flow of water with a smaller culvert and I am sure your neighbors will then not be very neighborly.
Unused Delta Crash...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
1265 (A50490)
1265 (A50490)
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
