Cultivator questions
   / Cultivator questions #1
Paul_C
I want to be able to plant a large garden (about .5 to 1 acre) and need to be able to create hilled rows. I was told that a cultivator can do this. Is this the case?
I'd also like a cultivator in any case so I can weed between rows. I have a Mahindra 5525 (54hp) tractor that is about 6' wide. Do I need a cultivator of a certain width? Do I need a 1 row or 2 row cultivator? My soil largely consists of clay but isn't that hard.
Is there a particular cultivator you'd recommend or have me avoid?
Thanks
   / Cultivator questions #2
Thanks
Maybe this is what you need
Bedding Attachment
   / Cultivator questions #3
Thanks
I have clay soil. If you attach field sweeps to the tines of a 6' wide 2 row cultivator you will be able to create hilled rows.
Paul
   / Cultivator questions #4
Agri Supply has what's called a Keulavator that'll accept both cultivator tines and opposed discs to make raised rows.
I've an old JD M soil ripper that has a diamond tool bar. I can put opposed discs or up to 7 cultivator tines or a combo of both. Attached are some pics.
Think you'll want your rear tires to run between the rows. You'd want 2 or 3 tines behind each wheel. For raised rows, just run the opposed discs behind each wheel.
Ralph
2012 Chevrolet Equinox 1LT SUV (A50324)
2012 Chevrolet...
Airman (A50322)
Airman (A50322)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
Wooden Barge Wagon (A50515)
Wooden Barge Wagon...
