Cubcadet RZT50 PTO burned up !!!
   / Cubcadet RZT50 PTO burned up !!!
Socket size for the flywheel on my 22hp B&S v twin. My 1inch socket was too small.
   / Cubcadet RZT50 PTO burned up !!! #12
Courage is no more. Kohler had continuing issue with it, poor design. My wife has one on her zero turn (CC RZT) and it an oil burner. Not impressed. In fact I use it to burn my waste oil. Very efficient at that...lol
Actually the Courage has been redesigned with different internal parts and is now called the 5400 series. Still a bucket style block. And the twin is the 7000 series.
   / Cubcadet RZT50 PTO burned up !!! #14
Overall, I'm not overly impressed with the new Kohler engines. Now my old school K241 is a solid engine and it's cast iron (except the head), not pot metal (pressurized die cast mystery metal)...
   / Cubcadet RZT50 PTO burned up !!! #15
If the diodes go bad in the rectifier, AC current will also take out electrical components.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
3" X 4" GAS POWERED WATER PUMP (A52708)
3" X 4" GAS...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2024 ArmorLite Aluminum End Dump Trailer (A56435)
2024 ArmorLite...
2023 Bobcat E60 (A53317)
2023 Bobcat E60...
