cub cadet start problem.HELP!
/ cub cadet start problem.HELP! #1
ddrone
cub cadet hds 2185
ok,I have a cub cadet hds 2185.It will start up and run fine,but if I shut it off and then try to restart it after 5 minutes or so,it wont start.Now if I shut it off and then re start it immediately,it will start up.After 20 minutes or so,it will start up again.Thinking coil?
new filter,plugs.
/ cub cadet start problem.HELP! #4
Almost sounds like a vapor lock after it sits for a few and gets hotter then when you let it cool off it starts again? Like metioned check you fuel line routing and try to keep it away from any heat source!
dont think so.Sometimes it has to set for hours before it starts.Even when I spray starter fluid in the carb it wont start.I checked the spark plug for spark,which it has,buy dont know if its hot enough.
It seems like it draws a lot from the battery when cranking it over,as it seems to pull from the battery,and has just enough to start it.It is a new battery.same thing with my bump starter.
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
Kubota GR2020G (A63688)
Kubota GR2020G...
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
