Cub Cadet Snowblower - Converting Power Chute to Manual Chute
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #11
Wow....so happy I found this thread. I have a Cub cadet 826 with this same motor. My motor went bad 2 years ago and when I found out CC's price for a new I decided I would just have to live with it. For the last two years I have been strtegically blowing snow since the chute always pointed the same direction lol. Ordered the replacement motor through my local Napa for $40...should be in tomorrow.
Thanks!
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #12
Well, bought the motor from Napa for $30 after core turn in. I had to tap the holes in the new motor as they were smooth bore.....5/16x18 threads........also had to grind off a fin on the case that was in the way, maybe 1/4" max...just used a floor mounted shop grinder. Electrical plug was identical and required no modifications. Took about 1/2 hour from start to finish and the chute is back in service! Thanks to everyone for the replacement part number for the motor! Sure beats the $250 Cub cadet quoted me just for the motor itself!
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #13
Thanks, I ordered the motor and with a little grinding had it on in a half hour. The connection matched perfectly. It now works better than it ever did.
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #14
When you state grind off fin, is that the fins near one of the bolt holes? It appears to me I would need to grind them off so it could get but that chute stop on the bracket. Is this correct. Oh, thanks for the bolt hole tap spec.
AWK
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #15
I finished it. I had to grind of the fin that makes contact with the metal chute stop on the bracket. Tapped the 5/16 x18 thread into the gear housing on the motor (came with smooth bore bolt holes). Fits well. Now I have a electrical problem. I think I have a bad contact from corrosion.
AWK
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #17
I know this is a old thread that strayed off topic but I just want to say thank you to those who commented as it help me save some $$$ and I now have a Cub Cadet 826 SWE snowthrower with a new electric chute motor with minimal modification that can be done with a hacksaw, hand file and tap.
Even if one purchased the basic tools, he would still be under the cost of a dealer priced motor. Well done guys! Got my Dorman 742-119 from Autozone for about $50.00 though you can get it elsewhere for less if you'd like to wait a few days. I decided to take advantage of a clearing in the weather and get this done. And it worked great!
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #18
I HAVE A Cub Cadet 826 SWE SNO THROWER Where do i get a motor to replace the burned out one for the chute?? With out spending a arm and a leg like CC wants for a new replacement motor??
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #19
Maybe check the post just above yours.
   / Cub Cadet Snowblower - Converting Power Chute to Manual Chute #20
I unfortunately didn't try this. Last January mine went out and I ordered the OEM motor from M & D Mower. I installed it and it worked but we didn't get anymore snow and it sat until yesterday. When I went out to use it again, it was locked up. I called them and they only have a 90 day warranty. They guy at MTD (Bill) was not concerned at all that I paid $250 for it and didn't use it since we didn't have any snow. He just said they have a 90 day warranty and I was out of luck (not very friendly either). They guy at M & D tried to get it under warranty but MTD said no. So now I ordered the door motor for $45. I learned my lesson. I could buy 5 of them at $45 for the one OEM part I bought. I will post an update when this comes in. Thanks MTD for taking my $250 and giving me defective merchandise.
2007 Chevrolet Uplander LS Van (A55853)
2007 Chevrolet...
John Deere Miniature Decorative Truck (A55853)
John Deere...
Toro Zero Turn Lawn Mower (A56857)
Toro Zero Turn...
2017 Chevrolet Sonic Premier Sedan (A55853)
2017 Chevrolet...
2009 Mariah SC23 23ft. Cabin Cruiser with T/A Boat Trailer (A55853)
2009 Mariah SC23...
2008 MACH CHU613 TRI AXLE 16FT DUMP TRUCK (A57880)
2008 MACH CHU613...
