Cub cadet popping sounds
   / Cub cadet popping sounds #1
MaggiQ
Cub cadet LR
I have a cub cadet XT42 one year old, 44 hrs on the engine, did oil and filter change last month, today is is making coughing/sputtering sounds with pops that sound like gunshots , what does it want? I checked the oil, it is right at the L level on the stick, someone please help.
   / Cub cadet popping sounds #2
Maggiq Welcome to TBN 📣
Sorry to hear that you are having issues with you CC. You have a:
  • 3-year/no hour limit warranty (includes powertrain) and 5-year chassis and front axle unlimited hours.
On you tractor. My suggestion is not to do anything with it. You don't want to take a chance on doing something that would void your warranty.
Contact the place that purchased it from and ask them for help.
There are a lot of things that could cause this.
Here is a link to the Cub Cadet thread on TBN:
You may have better luck there.
The moderator should move this to the CC tread.
Richard
   / Cub cadet popping sounds #3
Check your choke linkage.
   / Cub cadet popping sounds #4
Make sure spark plug caps firmly snap on plug.
   / Cub cadet popping sounds #5
I have had excellent rapport with Cub Cadet and their service reps. If you sound like you know what you are doing, they will okay you for an on site repair with you not having to worry about messing up the warranty.
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
Case Axial-Flow Combine Wheels NO RESERVE (A56436)
Case Axial-Flow...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
2012 MCLAUGLIN/VERMEER V800AWXT VACUUM EXCAVATOR (A57880)
2012...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
