Cub Cadet LTX1142 won't move
   / Cub Cadet LTX1142 won't move #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Have a Cub that when I move the hydrostatic foot levers, it gives a moaning sound & vibration. It won't move forward or back. Anyone had this problem before & find a fix.
   / Cub Cadet LTX1142 won't move #2
chances are your hydro is toast... but, you can check several other things: 1) look to see if your park brake caliper (located on the outside of the tranny housing) assy is frozen up ( a few shots of brake shoe cleaner fluid will free it up).. 2) with the deck removed and the rear jacked off the ground, chk the traction belt and pulleys for proper operation (BE CAREFUL)..3) lastly, you can remove the tranny in it's entirety; turn it over & drain the old oil from the top breather hole (will take a day or so) - catch all the old oil so as to know how much to refill; purge to eliminate air; retest. understand 20w-50 is a good replacement. good luck.
Thanks very much rcbe :)
It was the park brake lever & as you said, sprayed some lube on it & worked it some, problem solved.
Thanks Again
   / Cub Cadet LTX1142 won't move #4
always good to see the inexpensive fixes work... :)
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
2006 Acura RL Sedan (A55853)
2006 Acura RL...
JOHN DEERE BA84 WORKSITE PRO ANGLE BROOM (A54757)
JOHN DEERE BA84...
UNUSED FUTURE 32"...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
