Cub Cadet LTX1142 won't move
   / Cub Cadet LTX1142 won't move #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
Have a Cub that when I move the hydrostatic foot levers, it gives a moaning sound & vibration. It won't move forward or back. Anyone had this problem before & find a fix.
   / Cub Cadet LTX1142 won't move #2
chances are your hydro is toast... but, you can check several other things: 1) look to see if your park brake caliper (located on the outside of the tranny housing) assy is frozen up ( a few shots of brake shoe cleaner fluid will free it up).. 2) with the deck removed and the rear jacked off the ground, chk the traction belt and pulleys for proper operation (BE CAREFUL)..3) lastly, you can remove the tranny in it's entirety; turn it over & drain the old oil from the top breather hole (will take a day or so) - catch all the old oil so as to know how much to refill; purge to eliminate air; retest. understand 20w-50 is a good replacement. good luck.
Thanks very much rcbe :)
It was the park brake lever & as you said, sprayed some lube on it & worked it some, problem solved.
Thanks Again
   / Cub Cadet LTX1142 won't move #4
always good to see the inexpensive fixes work... :)
DIRT DOG CBX60 60" BOX BLADE (A57192)
DIRT DOG CBX60 60"...
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
34" EXCAVATOR BUCKET (A57192)
34" EXCAVATOR...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
