Cub Cadet LT1022-Grease nipples
   / Cub Cadet LT1022-Grease nipples #1
jetman356
Just brought it home. I found the grease nipples for the mower deck blade shafts underneath the deck. /forums/images/graemlins/confused.gif Doesn't make sense to have to take the deck off, turn it over and grease the shafts. The manual shows the grease nipples on top. Is my mower deck set up right?
   / Cub Cadet LT1022-Grease nipples #2
Dont sound right to me, I have had 5 cadets and they were all on the top.
Robby
   / Cub Cadet LT1022-Grease nipples #3
Go back to where you bought it and look at another one. Ask whom ever if it is correct. You should have no problems with getting the issue resolved. G
E-mailed Cub Cadet, and they said this is the way it is suppose to be. I bet the first rock that flys up over the blade shears the nipple(s) off. Doesn't make any sense /forums/images/graemlins/crazy.gif, but I guess I should have been more attentive when looking things over before I bought.
   / Cub Cadet LT1022-Grease nipples #5
If you have rocks flying over your blades, you'll have bigger problems than sheared nipples.
   / Cub Cadet LT1022-Grease nipples #6
The 1022 does not have as good of spindles as the rest of the cub cadets. All the other models have roller bearings and are greaseable from the top. The 1022 has a cheaper system. The brochures show that they are all the same, but that is not the case.
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
JOHN DEERE 460M LOT NUMBER 258 (A53084)
JOHN DEERE 460M...
1995 Rinker Captiva 190 (A53472)
1995 Rinker...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A52576)
2019 HINO 195 16...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
