Cub cadet log splitter dripping fluid
   / Cub cadet log splitter dripping fluid #1
Tjmac
Huntington
My splitter has about 60 hours on it and started to drip fluid from the part of the control valve that looks like the old 35 mm film canister. There are two Allen head screws that look like I can access it. Any suggestions what to expect when I loosen them? Is there an opportunity to replace a gasket, that is faulty?
Thanks for the comments.
   / Cub cadet log splitter dripping fluid #2
Pics would be nice but sounds like a reseal job is needed (more than likely standard orings)
Be carefull if the valve has auto return or pressure detent
Yes it does have an auto return but I would be doing this with no pressure on the line, what do I need to be careful of?
   / Cub cadet log splitter dripping fluid #4
Just be carefull when you take it apart. ya don't want to lose any pieces/washers/balls/springs.....
Put it back together clean, clean, clean........a can of carb spray (or similar) will help
   / Cub cadet log splitter dripping fluid #5
Well you probably don't want to hear this but many of us work equipment that weeps or drips lube. I'd just keep an eye on it...if it get steadily worse then I'd deal with it.
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
More info coming soon! (A56858)
More info coming...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A60460)
2019 Caterpillar...
