Cub Cadet / Kohler -> not so good
   / Cub Cadet / Kohler -> not so good #31
TENet said
"As a matter of fact, this occurred when I shut the engine off, and it did backfire, as it always does. (Yes, I've read the threads, I do throttle it down first, but I've taken to throttling down, turning the key, and quickly covering my ears. The neighbors think it's a hoot to watch)."
This is from my Craftsman 16 hp kohler engined mower manual (I don't know which engine series)
PROBLEM - Engine backfires when turning off
CORRECTION - Move throttle control to 'SLOW' position and allow to idle for 30 seconds before stopping engine.
   / Cub Cadet / Kohler -> not so good #32
Let's see we've got one valve seat falling out and whatever greenies' problem was.
Oh, that's enough to condemn the whole engine line. STOP THE PRODUCTION RUN!!!!
I had a Suzuki DR-Z400 dirt bike. It was known for having a suspect cam chain tensioner. One broke on me at 12,000 ft in Colorado. I fixed it on the trail and ordered a new one when I got back home. I replaced it with a new one, knowing the real fix was an aftermarket manual cam chain tensioner. The new one broke on first ride with it, this time causing valve damage. Did I blame Suzuki? No. I took my lumps and went on. I parted the bike out and bought a KTM 520, which I have had now for 9 years with no problems. Sometimes you git bit and sometimes you don't.
That's the real world.
   / Cub Cadet / Kohler -> not so good #33
TENet, I've read post before on here where their Kohler engine went south after the warranty ran out and they had some luck with getting some help from Kohler. You have nothing to lose calling them and seeing if they will help you get your engine running again. BTW, I admit to hearing some bad stories about the Kohlers, but they really are few and far between. As far as the B/S engines, I own a vanguard and it's been a great engine, but I have personally seen some issues with the cranks being weak in there cheaper models. I'm pretty sure that the Briggs engines that JD puts in there cheaper models have a crank that is made to JD's specs and is not the same crank that is in their other engines. Hence why it's called a JD engine built by Briggs and Stratton.
AJ
   / Cub Cadet / Kohler -> not so good #34
you actually believe that deere has motors built to specs. thats funny does deere even make those or are the assembled by mtd or like my poulan pro "this one still cracks me up" electrolux.
   / Cub Cadet / Kohler -> not so good #35
This thread has been pruned, some posts removed and some PMs sent. Please stay on the topic and leave the bickering out of it. It doesn't help the original poster. Thanks.
   / Cub Cadet / Kohler -> not so good #36
Not sure the OP was looking for any help. Looked like a statement of opinion. Looked like brand bashing to me.
Sure. i'd like to hear about problems, but simply state what happened and leave opinion out of it(as much you can when you are upset). As I stated about the Suzuki engine I had problems with I always went to dirt bike web sites and encouraged owners to change out their cam chain tensioner. I didn't blame Suzuki nor the part supplier that made the tensioner. The engine was great besides having a part that could cause a fatal catastrophe.
The middle of the story; I was able to buy all the parts I need (I think, so far) for $ 254, which is not so bad. Plus that included new filters and oil.
I tried Kohler twice, but got no response, I doubt it's worth it to go further. I did go to the Cub Cadet web page, where they list the top selling engine parts. Out of the 9 top sellers, one is the cylinder head I needed. I suspect I'm not the first one with a problem. (Hope the link works) CubCadet - Top Selling Engine Parts - Category
Anyway, if all goes well I'll be back to cutting grass in a few hours. Thanks very much to all who lent support.
And, a by the way... the guy at Kohler parts distribution told me that Kohler insists you MUST, MUST, MUST use 10W-30 oil. The Cub Cadet Owners Manual says 10W30 or 10W40, but (according to this Service Distributor) even topping off with 10W40 can cause lifter problems. He advised me to replace the lifters and all new cylinder head bolts along with the other parts. Just FYI, I'm only telling you what the guy told me...
   / Cub Cadet / Kohler -> not so good #38
Glad you got the parts at a reasonable price. Glad to hear you will get it back to a useful state. Sorry you had the problems.
   / Cub Cadet / Kohler -> not so good #39
as far as backfire issues, you need to shut the engine off with throttle at 2/3rds open or higher, here's why:
The electric solenoid on the carb shuts the main jet when turned off, but not the idle circuit as you might know. So..... with the throttle butterfly at or near wide open, insufficent vacuum is present to draw in fuel from the idle circuit and the solenoid closes the main jet. This means no fuel to the engine and no backfire.
If this is not followed and you idle the engine expect a backfire as you are not following Kohler's procedure for all engines which have a carb solenoid. Older engines did not have this and idling WAS the proper procedure on these. Practically all new engines use the carb solenoid and with any brand the advice is the same, 2/3 rds or higher throttle at shutdown.
Backfire may cause a head gasket to fail as well, have seen this quite often.
Now on the valve seat issue, my take: Typically this happens when a lean condition or lack of cooling is present. Take sure the intake manifold gasket or o-ring was in place and intact. If not that would constitute an assembly defect, plain and simple. Seen a few of these leave the factory with intake leaks and one cylinder running lean. Check the intake manifold for leakage also. It happens. If that was the case you have a means to ask the factory for assistance. Take it to them directly or ask an "area service rep" from their distributor to intervene, they have the power to help you as the "eyes and ears" of Kohler at the location. I know.
   / Cub Cadet / Kohler -> not so good #40
On our Kohler Command engine I choke it to shut it off. Let it idle down for a minute choke it and turn the key off just before it sputters.
No backfires or post ignition drama. imo backfires are something to be avoided...bad news.
You may be flooding the cylinders with raw gas doing that which will wash the oil off the cylinder walls and cause increased wear on starting and possible oil dilution. The old Kohlers (1450 vintage) required closed throttle on shutoff and the newer ones (3235 vintage) require 1/2 to 3/4 throttle.
Bob B.
John Deere 1025R (A53317)
John Deere 1025R...
2017 Polaris 500 Ranger Diesel Utility Cart (A55787)
2017 Polaris 500...
2017 John Deere 35G (A55973)
2017 John Deere...
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
2021 Kubota SVL75-2 Track Loader (A55315)
2021 Kubota...
2019 FREIGHTLINER SD122 DAY CAB (A57880)
2019 FREIGHTLINER...
