Cub Cadet Hydrostatic Oil
   / Cub Cadet Hydrostatic Oil #81
So, I see it has been at least 5 years since this thread was started and I would like to know what the original posters ended up using in their CC? I recently bought a used 2005 GT2521 and was flabbergasted at the price of a gallon of the CC oil.
So fess up, what did you use and how is it working for you...
Fess up? I'm at ~5yrs and counting with Shell Rotella-T 15w40 in the trans of my 2005 model year 2544.
Joel
   / Cub Cadet Hydrostatic Oil #82
I see Joel has been using Rotella 15w40 in place of CC Fluid Plus. Has anyone been using Mobile 1 in place of CC Fluid Plus in a tractor that specifies CC Fluid Plus only. If you have please let us know. Fluid Plus is $54 a gallon with tax here. My 5234DE with Hydrostatic drive takes 5 gallons.
   / Cub Cadet Hydrostatic Oil #83
I have been using mobil 1 15w50 with no issues. I do preheat the tranny
with a small heater in very cold weather.
   / Cub Cadet Hydrostatic Oil #84
I'm adding a logsplitter to the mix today and am going to try Schaeffers Simplex. My dealer said anything other than CC fluid is a bad idea. I had the Schaeffers guy look up application for hydros in the book and the Simplex ( which is synthetic) is recommended for EVERY hydrostatic drive out there. So how come it won't work in my Cub? 8/
   / Cub Cadet Hydrostatic Oil #85
What is the price of Simplex oil?
   / Cub Cadet Hydrostatic Oil #86
Joel
I changed the OEM fluid in my '05 2544 this spring at 165 hours. I'd changed the filter twice before and topped it off with the OEM fluid. This year I decided to dump it all and refill. It didn't look BAD, but didn't look good, either - kinda grayish, but still transparent, felt fine and smelled fine.
Filled it up with 15W-40 Rotella and a new NAPA/WIX filter and spent today carting around 12 yards of mulch and it operated just like always.
Chris
   / Cub Cadet Hydrostatic Oil #87
I just looked up Schaeffer Simplex, it is a Synthetic Blend. Didn't see a Full Synthetic on their list. I'm staying with a Full Synthetic. I think any brand would do. Mobile 1 is 1/3 the price of CC Plus.
   / Cub Cadet Hydrostatic Oil #88
Just got a 2010 sc2450 and needed to top off the hydrostatic drive. My dealer used Hy-Tran ultra and said it was the same stuff that CC sells by the quart at much higher $. He said if I brought the 2450 back to his dealership for service, that Hy-Tran was what would be used when hydrostatic drive fluid was changed. Hope this helps.
   / Cub Cadet Hydrostatic Oil #89
I don't doubt Hy-Tran Ultra will work, but we don't know what the specs of this oil are. Regular HyTran is a typical hydraulic oil in the 20wt range (like most every hydraulic oil or ATF is). Cub Drive System Fluid Plus is more like a 40wt per specs. As much as I'll experiment, I wouldn't use HyTran in place of Drive System Fluid Plus. Maybe HT Ultra is more viscous.
Joel
   / Cub Cadet Hydrostatic Oil #90
The original question of this post was a search for a suitable replacement for expensive CC hydrostatic oil. My point is that a CC dealer is using HY-Tran Ultra, claiming it to be identical to CC hydrostatic oil plus. He is the one I will deal with if a failure happens during warranty. If he has no fear of CC testing using Hy-Tran Ultra, neither do I. Hy-Tran Ultra does appear to pour in a 30-40 weight manner.:thumbsup:
2017 Kubota M7060 (A53317)
2017 Kubota M7060...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
Harley Davidson (A56859)
Harley Davidson...
2017 Ford F550 (A55973)
2017 Ford F550...
ATTENTION PLEASE READ (A53317)
ATTENTION PLEASE...
Miniature Metal Donkey Statue (A55853)
Miniature Metal...
