Cub Cadet GT 2550
   / Cub Cadet GT 2550 #11
I have a 2010 GT2550 also and have put 80 hrs on it. I had the same problem with the bolts you are referring to. They just act as spacers between the upper and lower reinforcement plates at the rear of the deck. There is a tube the bolts go through. Mine were not even squeezed up tight. I tightened them and then cut the excess length of bolt off flush with the nuts. It helped, but the nut will still drag occasionally.
Check the two screws on the hood hinge that hold the bracket to the top rear of the hood. Mine worked loose and fell out. I had to replace them with a size larger self tapping screw.
Also the fuses for ignition and the 12v outlet were reversed on mine. I found it the first time I plugged my tow behind sprayer in and it blew the 5 amp fuse. The other is a 15 amp. It should be 5 amp on the ignition and 15 amp on the outlet.
   / Cub Cadet GT 2550
Thank You
Bruce
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A55973)
2015 Ford F-350...
SUV (A59231)
SUV (A59231)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2008 CAT D6T DOZER (A58214)
2008 CAT D6T DOZER...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
