Cub Cadet 5234d problems
/ Cub Cadet 5234d problems #1
RVHobson
Saint John, NB, Canada
Cub Cadet 5234d
I have owned a Cub Cadet 5234d for about 6 years. It has done a lot of heavy work; mowing, hauling heavy trailer about 1000 lbs, and landscaping with 48" box blade. I learned that I must always use 4WD doing heavy work to save the rear differential gears.
A seized U-joint in the primary shaft from engine to hydro transmission (Hydro-Gear BDU-21L-400) caused the hydro input shaft to shear off. After repair with new drive shaft (including U-joints) and input shaft, it worked about 100 hrs until recently the input shaft sheared off again. This time the drive shaft had been greased quite regularly, so U-joint should not have been the cause. Has this same thing happened to others?
I suspect the offset alignment of engine output and hydro input causes the U-joints to fatigue the input shaft. Has anyone tried using CV joints instead of U-joints on a primary drive shaft? Are there small CV joints available that can handle 3000+ rpm?
Should I repair it again, or just look for a replacement?
/ Cub Cadet 5234d problems #2
I just had the same exact thing happen! I can't seem to find a new hydro gear or repair parts. Where/how did you get your repaired? The problem that I can see is that the input shaft is way undersized as opposed to the output shaft from the engine. I was just mowing when mine sheared off. Any help?
/ Cub Cadet 5234d problems #3
were you ever able to find parts? i had the same thing happen to mine
/ Cub Cadet 5234d problems #4
I DON'T THINK ITS AN ALIGNMENT PROBLEM-RATHER THINK TWO REASONS, ONE BEING THE CROSS JOINT IS TOO SMALL TO STAND HIGH R-P-M-S ,AND MAKING SURE GREASE OOOZES FROM ALL FOUR CUPS--AT TIMES YOU MIGHT NEED TO ROTATE THE SHAFT AND TAP THE CAP UNTIL THE GREASE COMES THROUGH, A LITTLE HEAT [JUST A LITTLE NOW] THOSE NEEDLES IN THE CAP WHEN DRY WILL GET RED HOT AND SEIZE, THIS WILL SNAP THE PIN, THIS THROWS THE SHAFT OUT OF ALIGNMENT, WALA--- PROBLEM--THAT'S WHAT I'M UP TO AS WE SPEAK, ONLY I'M GOING TO TRY A RUBE GOLD BURG FIX, ILL LET YOU KNOW HOW I MAKE OUT. GREG.
/ Cub Cadet 5234d problems #5
PERHAPS I SHOULD EXPLAIN, THIS TRACTOR WAS GIVEN TO ME BECAUSE THEY COULD NOT GET ANY ONE TO FIX IT, ITS LIKE NEW, I THINK THEY SAID IT IS A 2O15-- [HOW CAN I FIND OUT]
/ Cub Cadet 5234d problems #6
hi, looking to buy a cooling fan for a ser 5000 5234d tractor, mine broke when the drive shaft snapped off,thanks for the help- also looking for advice on replaceing input shaft on the hydro rear. Richard.
/ Cub Cadet 5234d problems #7
I just picked up one of these tractors with a snapped off input shaft on the hydro pump, did you end up doing that repair? How did it go?
/ Cub Cadet 5234d problems #8
5234d,why would it skip over teeth in forward but not reverse any help appreciated.
60in. Skid Steer Bucket (A65640)
60in. Skid Steer...
213201 (A64277)
213201 (A64277)
2018 Chevrolet 3500 HD (A64127)
2018 Chevrolet...
Metal Mailbox (A64127)
2005 International 4300 Rollback (A62613)
2005 International...
2011 Bobcat E80 (A64126)
2011 Bobcat E80...
